rtv rubber bushing
   / rtv rubber bushing #1
kabootie
i was trailering my rtv to a near by trail and when i pulled it off the trailer i noticed a piece of rubber laying on the trailer floor . i am about 95% sure it was not there before i loaded the rtv up. it about 1 inch by 7 inch by 1/4 thick i have looked under the frame cannot see anywhere it goes. looks like some kind of bushing a radiator or fuel tank or motor would set on to keep vibration down it has a number on it (k756156712. 04. 2. 22) if any one noes where this goes please let me now it drove good today but if some thing is missing i would like to put it back thanks
   / rtv rubber bushing #2
Can you post a picture of it?
   / rtv rubber bushing #3
kabootie,
I'll think about what it might be but if you contact your dealer and have them look up part #K7561-56712 using the RTV parts manual, they should be able to give you the text description and location.
I did an online lookup of that part number and got a truncated description of "Cushion, Cover C" if that helps.
Brian
   / rtv rubber bushing #4
Kabootie: Here's a picture of your part from the RTV Parts Manual. I hope it helps. It is part #80.
Good Luck
Andrew
  • 729499-RTVParts.PDF
thanks for all the replies a finelly got a hold of dealer and they said it was a bushing that goes between the plastic bottom part that the seat sate on between the tubular steel frame and the plastic seat support ill check it out this weekend i supose it glues on there wher some weather striping type glue on it
   / rtv rubber bushing #6
bczoom is right on, except the newest part (revision) is K7561-56713 (Center Cover Cushion) which has a better adhesive applied. /forums/images/graemlins/smile.gif
3 PT DIRT SCOOP (A51243)
3 PT DIRT SCOOP...
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
1967 Minneapolis- Moline Super  M670 (A50514)
1967 Minneapolis-...
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
