RTV Hydraulic utility valve kit
   / RTV Hydraulic utility valve kit #1
rjslota
Ocean County, New Jersey
John Deere 4110
Yo! Sombody mentioned a Hydraulic utility valve kit for the RTV to let ya run stuff off the back like a log splitter. I couldn't find a listing on one and was wondering the cost and if it would be easier to get a new RTV. As soon as I get a nice day I'am going to install the coast valve and see how that works. Thanks.
   / RTV Hydraulic utility valve kit #2
Hi there
I think there is valve on E bay now that will do what you want it's on rtv site.I just got a valve from northern has to be hand operated push pull,I think the e bay is electrically operated so can be used with switch.You won't be sorry Installing coast valve makes rtv a pleasure to drive.
Thanks for the reply, I need some time with the coast valve since the directions came looking like a black bear at night. Can't see a thing I'll use braille. Right now it has a flat tire, bad valve stem, I'am going to put screw on tractor type valves on this time. The hydraulic system is another project. I've seen the units installed on other RTV's and it has another fluid tank, I guess to disperse heat. I did find a hand trottle on ebay so I have a start. Once again thanks. I'am going to list a new note about where and for how much I got this RTV, The crew will be jealous!
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
Quick Attach Trencher (A50121)
Quick Attach...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
