RTV hand throttle cable routing?
   / RTV hand throttle cable routing? #1
Wayne_H
Davidsonville, Maryland
John Deere 4400, '48 B and 318
Can anyone send me a picture of where the hand throttle is supposed to route where it goes through the frame? Right now I installed it sitting on top of the frame, but that does not look right. I don't see a logical place for it to go, and the directions don't show it, they might as well be written in Chinese....
Thanks! Wayne
   / RTV hand throttle cable routing? #2
Thanks! Wayne
I installed mine under the frame so it could be zip-tied to the emergency brake per the instructions.
R Watler: I did too, but it just seems to be hanging out in the open, several inches in front of the rear wheel. It is zip tied like they said, but not routed cleanly like all the other stuff.
Any chance you might be able to snap a shot of it?
thanks
Wayne
   / RTV hand throttle cable routing? #4
Mine was also hanging out in the open until I tucked it behind the rubber battery cover a little. You just have to be somewhat careful shutting the hydraulic bed from the raised position.
I wasn't able to make the collar fit at the attachment point to the throttle lever. How about you?
I got the color to fit, but I had to squeeze it quite a bit. Any chance anyone with a factory installed hand throttle could post a picture of the routing where is goes near the frame on the battery side?
thanks!
Wayne
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2007 Ford Taurus Passenger Car (A51694)
2007 Ford Taurus...
Duetz Power Unit (A50120)
Duetz Power Unit...
