RTV Front Grill Guard Protector
   / RTV Front Grill Guard Protector #1
caylor
Upshur County, Texas
Kubota L3130 w/513 FEL Quick Attach, Kubota RTV900
I have several gates on my property that I open with my truck using a standard Texas Gate opener, which I understand in other parts of the country is called a Grill Guard. :)
I have rubber covers over the vertical members of my grill guard (Ranch Hand Brand)that keeps the powercoat from being scraped off when I "open" the gate.
I would like to do the same thing using my RTV grill guard, but I have no "scarifical" protection (i.e. rubber to cover the steel). Has anybody modified the guard on their RTV to do this? My first thought was to strap on some foam pipe insulation covers over the steel, but that seemed kinda like a rinky-dink solution. Any Ideas?
   / RTV Front Grill Guard Protector #2
The foam will probably rip.
There's lots of hoses that could be used.
Radiator hose
Clothes washer hose (if it's the right diameter to match the smaller pipe).
Sludge/irrigation hose
Slit it the long way, slide it on and zip-tie it in place.
   / RTV Front Grill Guard Protector #3
Hydraulic suction hose would be a great hose to use. It has a very tough cover with a single cloth braid, should provide plenty of protection. I would contact cement it to the tubes using hose clamps at the ends to secure it.
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
(4) 12' & 10' Corral Panels (A50515)
(4) 12' & 10'...
2018 Jaguar XE Sedan (A50324)
2018 Jaguar XE...
Unused Combine Chopper (A50515)
Unused Combine...
County Line 5' Poly Feed Trough (A50515)
County Line 5'...
