RTV Electric Fan Overheating?
   / RTV Electric Fan Overheating? #1
horsinaround
down the road a bit
Kubota L5740 Kubota F3080
What a great little machine. We took delivery yesterday of our Recreational RTV and ran it all over the farm. As we ran it, I noticed that the temperature climbed a little closer to the "hot" than I liked. Didn't over heat, but then, we didn't run it hard either.
I prodded around and checked the coolant and it is fine. I noticed it has an electric fan.
For those of you that have more hours on yours than I have on mine, where does your temp normally run? At what point does the fan come on? I will call the dealer later today, but it is too early now and I thought I would ask the pannel of experts out there that have more hours of use than I do. I will be catching up soon though.
By the way... What a great machine.
Thanks for the input.
   / RTV Electric Fan Overheating? #2
I have got mine in some seriously bad sitiutaions. No air flow, stuck in the bottom of ravines and hours and hours of rocking back and forth trying to get out in 100* weather with no signs of overheating. Though I don't recall a actual temp reading on the guage I can't ever remember seeing it being more than halfway.
   / RTV Electric Fan Overheating? #3
had same problem with my rtv. fan didn't come on when it should. dealer had to replace sensor that controlled fan.
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
2020 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2020 CANYCOM SC75...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
