rtv 900
   / rtv 900 #1
VA MTN MAN
Virginia
kubota m5700
Anybody had to replace a fuel tank,mine found a stick. What does a new one cost?
   / rtv 900 #2
No I don't know how much a new tank is but I think you can repair them if not to big of hole. good luck sorry about your misfortune
   / rtv 900 #3
I repaired the plastic fuel tank on my LS tractor with JBWELD. It has only been about a month, but it is still holding. It had cracked where the idiot design engineers embedded bolts to hold on a limb guard. I would try that prior to putting in a new tank. You may need to put in a backer strip of some type if the hole is large to keep the liquid JB Weld from running thru.
   / rtv 900 #4
Once repaired, you may want to do like I did and install a solid skid plate around the tank to keep future limbs at bay.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
