RTV 900 Windshield Wiper Fuse
   / RTV 900 Windshield Wiper Fuse #1
dkhunter
Does anyone know where the fuse is? I lost power and think its just a fuse.
   / RTV 900 Windshield Wiper Fuse #2
Do you have a overhead console, and are you running 2 wipers.
I have an 2004 RTV 900 with the Cab enclosure. It has one wiper with the motor on the inside where the wiper blade exits the windshield.
   / RTV 900 Windshield Wiper Fuse #4
I just checked my '07 900. Wiper was installed by the dealer w/hardtop. I have the original installation instruction which identify's the wiper using an in line fuse. What it doesn't identify is the exact location of the 12v connection. On my unit that connection point is under the hood, near the r'frt shock tower. The in-line fuse shape is cylindrical and balck in color w/red wire. The fuse is a glass BUSS type, 8 amp. If the fuse is good (ck w/ohm meter), then I suggest ensuring there is power at the pick up point. Easily done w/a 12 volt test light or DVOM. Just remember to test w/ignition on. The wiper should be a switched accessory. If there is no power, then head to the fuse box at the back of the cab. Test all the fuses.
Hope that helps.
Grundfos Centrifugal Pump (A50121)
Grundfos...
(2) Hydraulic Augers (A50121)
(2) Hydraulic...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
Ford 4600 (A50120)
Ford 4600 (A50120)
4 Disk Plow (A50121)
