RTV 900 tail gate/box vibration
   / RTV 900 tail gate/box vibration #1
redharley
central, Pa
BX2230
Ok I really like this machine but this is my biggest complaint. Has anyone come up with a good fix for this problem? Sitting at idle the tailgate will really vibrate badly,even at slow traveling speeds , I know from original they have 2 rubber pc's back there but mine are gone and they were never the perfect answer,Just thinking some one has come up with a more permanent fix since those little rubbers get missing often. Thanks for your thoughts
   / RTV 900 tail gate/box vibration #2
When I bought my 900xt, the dealer mentioned that rhino lining helped keep vibration noise down. I agree (have the factory spray in liner). The only vibration noise I get is an intermittant noise from the passenger side seat belt receiver.
   / RTV 900 tail gate/box vibration #3
i have had nothing but problems with the bed on my rtv 900. as for the rest of the machine, its awesome. i use mine to haul a lot of firewood and the two sides always seem to bend out a little bit when i dump off and then the tailgate wouldn't close. so i would have to tweek the two sides by pushing them towards each ather and then they would be at the right position for the tailgate to latch. over time of doing this, i noticed the little angle iron at the bottom rear of both side panels was cracking. so out comes the welder. after still more problems with it, i ended up welding the side panels to the bed floor, both inside and outside. problem solved. back to your issue, as i played around with the two side panels, i also noticed the vibration you spoke of and if i tweeked the side panels towards each other just right, the tailgate would fit tighter and no more vibration. this is where i put mine before welding the two side panels. no more vibration.
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
Case 480E (A50120)
Case 480E (A50120)
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
Semi Sleeper (A50121)
2016 Ford Explorer...
