rtv 500 on kubota site --
   / rtv 500 on kubota site -- #1
Unregistered2013
here it is --
Kubota Tractor Corporation | Utilty Vehicle RTV500
well, if you ever thought these things were starting to look like toys, i now have to agree with you -- :D
this fuddy duddy guy looks like he's driving a miata --
-- don't turn to quick -- she may roll!
:D
   / rtv 500 on kubota site -- #2
We should have one for demo at our dealership sometime in Oct. I will post some first hand pics if no one doesn't beat me to it.
   / rtv 500 on kubota site -- #3
we are suppose to have one any day now.
   / rtv 500 on kubota site -- #4
Does anyone know how much it will cost??
   / rtv 500 on kubota site -- #5
The first one arrived at my local dealer this week, and after a short test drive I bought it. It is the perfect size for my needs, the RTV 900 was too much. Have only put a couple of hours on it, but it is a hoot to drive and has handled all the terrain I have attacked so far. It lists at MSRP 8400, but I have seen it offered at 8K in my area. My wife loves it, and that was the rationale I used to justify purchasing it. Since we allready own other tractors and industrial mowers.
   / rtv 500 on kubota site -- #6
Ours showed up yesterday at the dealership,.. noticeably narrower and shorter. Took it for a test drive,.. still under powered, the engine should have another 5-10hp although it is very quiet. The rear 4 link suspension is "okay", but the seat is TERRIBLE! period, it rides so rough I was done after about 15min. Kubota should have at least used a softer foam cushion, I can see this only getting worse with time and the seat cracking.
It comes with small 24x9 tires front and 24x11 rear,.. and ground clearance is meager. On a side note, there is the opportunity for a 2" lift or taller to fit 25-26" tires, whether you could turn them efficiently has yet to be tested. Haven't found a way to tweak the throttle yet, like I did on the diesel models.
The dash layout is fairly nice,.. plain,.. but fine for what needs to be displayed,.. the shifting was a lot better than the 900/1100's. No gear train torque lockup when stuck on a hill or hole, when in LOW, goes down to HI, NEUTRAL then REVERSE. 4wd is a cable, lever lock into a notch, same as for rear diff lock,.. shifting is smooth and did not feel the fork lockups like in the 900/1100.
Lots of storage opportunity under the front hood,. no compartments other than the passenger glove box,.. mostly just empty space. From what I can see you should be able to fit 4-5 beer under the seat laying down.
The winch mount is OPEN,.. no more laying down in the mud, or climbing under the hood and reaching way down to free spool.
It is a nice machine,.. as long as a person doesn't expect more than it is capable of.
Well that is my review of a 15min drive.
   / rtv 500 on kubota site -- #7
A little edit to my previous post after having it out for the weekend. You can speed it up after you are already moving by tying a string to the throttle linkage at the carb. This thing climbs to beat ****,.. will have to check when I get a service manual,.. think it might have some sort of viscous diff lock in the front on these models now. The hydro is awesome for inching and feathering pedal.
If I wasn't planning on buying a Rhino I would buy one of these,.. I may even change my mind,.. not too sure.
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53342)
THIS WILL BE A...
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
