RTV 400 hard to crank
   / RTV 400 hard to crank #1
S C B
Illinois
Kubota L3400
Hi guys, I already posted this in the ATV-UTV forum but thought there might be Kubota knowledge here. I have a 2012 RTV400ci with less than 150 hrs on it that will not crank over without first barring the engine over a little or removing the spark plug, cranking it, and then reinstalling the spark plug. I have done a google search for similar problems and found two separate accounts where the owner said his dealer contacted a rep and then installed a compression release and it improved the starting of the unit. My local dealer does not know anything about a compression release and does not want to look into it. Have any of you guys heard of this problem and have any info about?
I have already adjusted the valves thinking it might be like a single cyl Briggs or Kohler but that didn't help either.
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
Fifth wheel multi use trailer. (A53472)
Fifth wheel multi...
2020 JOHN DEERE 6145M LOT IDENTIFIER 75 (A53084)
2020 JOHN DEERE...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
