RTV 1100c OEM rear window screen blocks 1" square "stake holes"?
   / RTV 1100c OEM rear window screen blocks 1" square "stake holes"? #1
pdsrms
Central NH
Kubota L39, B21
Anyone out there have an 1100c with a factory rear window screen?
If so can you still use the 1" square holes (i.e stake holes) in the corners of the bed? Looks like a very close clearance
   / RTV 1100c OEM rear window screen blocks 1" square "stake holes"? #2
Have the original RTV1100 bought in 2007 with rear OEM window protection screen.
You cannot put straight stakes in the corner of the bed and clear. In fact if your widow screen is not seated in the clips all the way, when the bed is raised it will hit the screen and if not careful will start to bend it in half.
Though if I ever needed bed sides, I would insert a short stake into the corner and attach an offset riser to clear the screen when you raised the bed.
CAT Skid Steer (A50322)
CAT Skid Steer...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2007 Ford Taurus Passenger Car (A51694)
2007 Ford Taurus...
2008 Volkswagen Passat Passenger Car (A51694)
2008 Volkswagen...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
