RTV 1100 I need more power
   / RTV 1100 I need more power #1
kentuckynet
Hello, i live on a small watershed lake and i drive the kubota rtv1100 to and from the lake. Sometimes it just barely climbs the hill. The other day it stalled out ontop and i had to roll backwards down the hill.
It has a new fuel filter, the machine has around 100 hours since new. I really cant afford to pay the 1900 bucks for a turbo...are there any tricks or adjustments to increase its power?
I have read about spark arrestors and adjuting the HST servo will either of these help me?
This machine has always been weak, its very slow to begin to move when you step on the pedal.....almost like the brake is on but its not. In wet grass it couldnt think about spinning a tire!
Any ideas would be appreciated.
   / RTV 1100 I need more power #2
My experience is with an RTV900. It has a huge amount of power and will go up any incline without the slightest hesitation, even with a load. It's ability to climb reminds me of a military tank! Yours must have a problem. I would be talking to my dealer.
Im long out of warranty and i dont care for my dealer, thats why i came on here looking for help.
Im quite certain theres someone on here that can tell me what i can do...
thanks
   / RTV 1100 I need more power #4
My 5 year old RTV 900 also gets a little slow when climbing near the top of our steep driveway approach, but the torque allows it to muscle through and it has never stalled. Of course, that is mainly due to my laziness of keeping it in M gear. If it gets steeper, I always use L and I think it would go up almost anything in that gear. What gear are you using?
Oh, if the fuel level gets low, it seems to lose more power and will even stall on a hill. If you are running it with the tank very low, try filling it up and see if it makes a difference. My gauge is dead and I have not looked into it yet, so sometimes I get down a ways.
Frank
   / RTV 1100 I need more power #5
Are you in high range? I might try the hill in the next lower range to see if it works better.
Aaron Z
   / RTV 1100 I need more power #6
It seems if you lift off the gas peddle some it helps too. The foot feed controls both the engine speed and the transmission shifting. If you lift your foot slightly, it seems the engine speed stays the same but the trans shifts down some. If you need more, shift to a lower range.
   / RTV 1100 I need more power #7
That is exactly what you have to do. If you keep the pedal to the metal, the hydrostatic keeps the plates arranged for speed not power and it will stall the engine. If going up a hill and it starts to stall, just back off the pedal and it will climb right on up. My 900 climbs hills pretty good in M without backing off the throttle but will start to stall going up a steep 30 degree slope if I keep the pedal down but just letting up about half throttle keeps it moving at the same speed. Most folks that have problems with these transmissions still have the more pedal = more power mentality and that is not the case with hydrostatic. I can actually load the FEL bucket with my Kubota B 26 in High range by just easing in the pedal but if I stomped it to the floor, it has no power. The RTV works similar only the throttle works both the engine RPM and the go pedal. If yours doesnt work for you when backing off the throttle, then you need to see a dealer. I rarely put mine in H range but it is pretty weak at climbing and acceleration in that range so I mostly keep it in M. In L and M it will dig holes with all 4 tires. I use mine to pull saplings by chaining around the front or rear tow hitch ball and yanking them out. It has plenty of power
Fuel is always full.....
In m i think i could put my shoulder against it and keep it from moving! Just kidding but its not a very strong machine! I really thought you were kidding.....im always in low and yes i do have the pedal on the floor...ill try lifting up a little and see if that helps. I have never changed the HST filter or the suction filter or changed the transmission fluid......would any of this help?
   / RTV 1100 I need more power #9
Yes you need to change the fluids with Kubota's SUDT, expensive but it is the best for these machines. As well as all the filters. That should have been done at 50 hrs so do it asap. Next change after that is every 100 hrs for the engine oil and filter and every 200 hrs for the hydraulic oils and filters. So not so bad given the low hours you are putting on. I use Mobil1 diesel engine oil and kubota oil and filters for the engine and hydraulics.
Next pull the 3 bolts out of the muffler tail pipe and remove the screen section that sits inside the muffler. I cut mine about 2" from the mounting plate, others have just hacked away the screen or drilled big holes all over it. Both works, but removing the 4 or 5" of screen and pipe seems to work the best.
Do you have a manual?
What year is this beast?
   / RTV 1100 I need more power #10
I've got an RTV 900 with just over 200hrs, using the correct gear it has never not done what I ask. I've dragged entire large trees, dragged 800 feet of fencing (oak posts connected by plastic strips) through feilds of high grass and over hills. i've got some very steep hills and my RTV climbs them as well as my JD 4720 with 66hp. neither are fast but they don't seem to mind. i hope you get it figured out. maybe another brand dealer will let you "test" some other models on your property or even another RTV to see if it's the unit or your expectation is not reasonable. another though is that I/we don't know if with your 1100 some of them have cab & a/c - mind does not and it could be a factor.
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
FIATALLIS MOTOGRADER (A50854)
FIATALLIS...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
