RTV 1100 hydraulic?
   / RTV 1100 hydraulic? #1
BobH
Union Vale NY
2002 NH TC33d
Does anyone know if the new RTV 1100 has utility use hydraulic outlets and what is the flow/pressure if they have them? I was looking at a 900 at the dealer yesterday and he suggested I wait and see a 1100 before I buy. He said by the time I option a 900 up similar to what an 1100 has standard there should be less than a $1000 difference. That sound right to you? Bob
   / RTV 1100 hydraulic? #2
The RTV1100 does have hydraulic outlets in the back similar to the ones on the RTV900. If you do a google search for "RTV1100" there are a number of sites with all the features and specs.
If you were to try and put all the features on a RTV900 that come standard with a RTV1100 (cab, heat/ac,wiper,rearview mirror etc) it would cost you close to 2k more.
Your dealer give you any info as to when the RTV1100 will be available?
I've looked around and can't find the specs. I'm looking for. A link would be appreciated. He said the first ones should be there by the end of April.
I must be loosing it. I don't see any info on the hydraulics on their spec page or anywhere else on the site. Thanks for the effort. Bob
   / RTV 1100 hydraulic? #6
Oh, I thought you were looking for specs in general. As far as the specs on the rear hydraulics only I would expect them to be the same or very close to what they are on the 900. On kubota's website they show a number of implememnts that can be run off the rear hydraulics on the rtv. As far as flow rate etc. your dealer should be able to get the specs for you.
I am just curious, is there some implement in particular that you are concerned about with regard to the flow rate?
After a weekend of charging batteries, pumping up tires and trying to get a bunch of seldom used equipment running I'm thinking about a small, around 5cfm air compressor and a 2000watt generator. Hydraulic motors driving them are small and usually trouble free so tucking them in somewhere on an RTV might be possible. Getting the generator running to run the air compressor to pump up the tractor tire to load the generator in the truck to go and charge the excavator batteries got real tired this weekend. That and sitting in the cold plowing snow has got me looking at an RTV. Mike, I see your not too far from me. Do you have an RTV?
   / RTV 1100 hydraulic? #8
For contually run attachments you should have the oil cooler attachment.
Another from the wilds of New York! The pamphlet only seems to have the more "common" attachments and Kubota's web site is non existent on the 1100. Where are you folks finding these options, attachments and information?
   / RTV 1100 hydraulic? #10
Bob, slow down, remember I think it was NY that had the first tax but not all things come from here first. There is a book with all the attachments and that doesn't show it yet but don't be alarmed. It will all be out soon. They haven't come out with the literature for it either and they normally don't until the machines are ready.
Kubota doesn't get into hyping people up before the release as when they do normally introduce something it is right!
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
