RR Rail Strength
   / RR Rail Strength #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
Is a rail suitable for overhead lifting? 20 -25' span. Would it have the capability of supporting 2000 lbs.?
   / RR Rail Strength #2
Dont know about the span strength, but it makes great ballast to counter the bucket on a BX series. Fits between the 3-pt real nice too!
   / RR Rail Strength #3
I see they make curves for the train to go around....and them ties are pretty close together.
Here's something that may make you want to consider an I beam.
Rail Deflection
Next time you're at a crossing,pay attention to the rails deflecting up and down.Of course I realize that those cars may weigh in at 200,000 lbs or more,but they are also supported every 19 inches or so by ties.
   / RR Rail Strength #4
Would depend a lot on the size of the rail.
We used to have one that spanned 24 feet across the garage.
We used it to pull motors and stuff like that.
It was a medium size rail. 4inches tall I think.
Had one years later to span a bay in my workshop.
It was a full size rail (6inches tall) and spanned 14 feet.
After setting that monster I can tell you I won't do another one.
Those things are ungodly heavy.
But that 14 foot span would have supported 2000lbs easy.
The 24 foot span would deflect a bit with a motor and transmission hanging from in in the middle. But nothing unsafe.
You have to secure your rail on both ends. Not only from pulling inward during deflection but also from rolling over.
Bout the worst thing that could happen is to pull it down on yourself.
Be safe.
Pooh Bear
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
2024 JOHN DEERE 3039R LOT NUMBER 58 (A53084)
2024 JOHN DEERE...
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
