Snowblower rpms??????
   / rpms?????? #1
welderwayne
calgary ab.
Toro Dingo 320 D
I have just acquired the front and business of a snowblower. It is 32 inches wide with 16 inch blade and a 12 inch second stage.
I want to quick attach it to the front of my Toro dingo 320 D.I haven't decided whether to mount a gas engine or run it hydraulically.the second stage is running approximately 11 to 1 ratio with for stage. My two questions are........
if I use a gas engine what is the minimum size engine I should use and how many RPM's should that input shaft of the snow blower be turning?
if I use a hydraulic drive motor what size of motor should I have, my machine put so 12 gallons per minute, again what RPM should the input shaft of the snow blower be turning at?
I am located in Calgary Alberta and we never know how much snow we're going to get sometimes it's wet sometimes it's dry. Thank you for any and all help!
   / rpms?????? #2
Can you match it size wise with a commercial powered walk behind? The specs should be published regarding horse power, rpm's etc. What powered the parts you now have? You shouldn't have to re-invent the wheel, power wise. Mating it up to your Dingo is another story. Giving advice on a snowblower from 17 degrees N. of the Equator is something I couldn't resist.
(INOP) KUBOTA RTV1140 CREW CAB ATV (A51243)
(INOP) KUBOTA...
M & M Grain Drill (A50515)
M & M Grain Drill...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51243)
1991 KALYN SIEBERT...
Year: 2014 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 82,181 Plate: Body Type: 4 (A50324)
Year: 2014 Make...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
