Row crop wheels & high clearance
   / Row crop wheels & high clearance #1
Emagri
These are some tractors we modified
NEW HOLLAND
JINMA
KUBOTA
MASEY FERGUSON
   / Row crop wheels & high clearance #2
NEW HOLLAND
JINMA
KUBOTA
MASEY FERGUSON
Nice looking conversions! Do you have those wheels made up custom? It looks like they are all from the same drawing board, but different dimensions.
In these pictures, we used the same drawings for all wheels, but actually we have a few different desings.
At the end we make the paint and bolt pattern, so we can modify any tractor brand, it doesnt matter if is 2wd or 4wd
   / Row crop wheels & high clearance #4
Just wondering...in 4wd...the new tire sizes do not mess up the gearing between the fronts and rears, (rolling distance)?
Is important to use the right size in every case, but is not a problem, there are many options for all tractors it doesnt matter if is a 4wd or 2wd, just mantein the rolling rhytm
   / Row crop wheels & high clearance #6
I got a chance to run a SAME tractor with a rice conversion like that a few years ago. neat conversions.
   / Row crop wheels & high clearance #7
I was really thinking on something similar on JM354 Jinma, but finally dropped the idea. I was wanting to do sweet corn cultivating but the new tires and wheels just got outta site expensive. I was thinking 28" rears and 20" on the Fronts.The other issue was, what does the tall tires to for ground speed and power? I suppose just don't go in High Gear down the Hiway with those puppies on. bjr
Jinma 354 is a popular tractor for row crop wheels. We usually modify this tractor with 48" rear 32" front. It can't be bigger for what you said. Speed.
Jinma 554 is better for this service because has speed reductor, so, we can go up to 54" rear 38" front
   / Row crop wheels & high clearance #9
Did the modified Jm354 have the gearing to go slow enough for cultivation with that size of tires? bjr
Not the 354, that is why you can use 9.5R48 only.
554 has the speed reductor so you can go up to 54 inches
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2017 JLG T350 35ft S/A Towable Articulating Boom Lift (A50322)
2017 JLG T350 35ft...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
Case International B600 Silage Blower (A50774)
Case International...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2023 Third Coast Equipment RA12H Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2023 Third Coast...
