Round-up / Glyphosate
   / Round-up / Glyphosate #1
WVBill
Veteran Member
Usa
Sold my Kubota B6100 when I moved to WA
Is there any way to extend the life of Round-up/Glyphosate once it's in the sprayer.
Sometimes when I mix up a 15 Gal sprayer tank I don't use it all. When I come back to use it in a week or two it has formed gelatenous globs in the tank and clogs the filter screen.
Anything I can add to keep that from happening?
   / Round-up / Glyphosate #2
Find somewhere to use it up, like the driveway. Or a neighbors place.
   / Round-up / Glyphosate #3
In my experience, glyphosate remains effective for an extended period after it is diluted for use. I've used some that sat over the winter, and clearly froze when the temps got to -5. It still worked. Remember that it is sold in various concentrations, that is, dilutions. So long as it is kept in a decent storage container, I see no obvious chemical reason why it would quickly degrade.
Chuck
   / Round-up / Glyphosate #4
Chuck
He's not asking if it will remain effective... he's asking how to stop it from globbing up his sprayer if he lets is sit for a week or so.
   / Round-up / Glyphosate #5
Ah yes, sorry I missed the point. Maybe I use a different formulation because I don't seem to see the globbing behavior.
Chuck
   / Round-up / Glyphosate #7
I have never had my Roundup glob up in a tank like yours Bill. I wonder why yours is doing that? Do you leave it in the sun? Only a week or two? That's got me bamboozled. Are you adding any surficants, or sulfate?
It's got to be the water. Where are you drawing the water from? Aside from globbing up...water drawn from a ditch, etc., is not good to mix with glyphosphate. The impurities will interact with the chemical and reduce it's effectivness. It's best from a well or tap.
   / Round-up / Glyphosate #8
i use glyphosate and 2-4d mix in my backpack and have left a gallon or so extra sit for a week or more in the sun on a number of occasions with no clogging/plugging/gelling issues.....
   / Round-up / Glyphosate #9
Seems everyone is too busy telling you how they don't have a problem with their glyphosate to help you with your problem. So...glyphosate is a sodium or calcium based product, so it is readily soluble in water...sounds to me like the problem is the surfactant used in whatever brand you are using (helps it stick to the foliage). I would think that a little hot water and some agitation would fix it. I wouldn't worry too much about a pint or quart of hot water in a 15 gallon sprayer diluting it to the point of making it ineffective. I make this statement by assuming and reading between the lines that you are using a concentrate. If not, I wouldn't add any more water than necessary. I use a generic sodium glyphosate concentrate and have had the same problem you describe with the surfactant coming out of solution after sitting for awhile.
   / Round-up / Glyphosate #10
Every generic brand I've tried gels up after a week, the high-dollar Roundup super-concentrate has never gone bad after sitting for over a month. So I use generic early in the season when I'm using lots of it then keep Roundup in the tank from about now thru July for touch up jobs.
Any trace of Roundup or 2-4d left in your tank when you mix some MSMA crabgrass herbicide or the other way around will also make a gelatinous mess.
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2006 Dodge Sprinter 2500 Van (A50323)
2006 Dodge...
2011 Ford F-350 XL (A50120)
2011 Ford F-350 XL...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52141)
1999 KENWORTH W900...
