Round bales and cleanup
   / Round bales and cleanup #1
New Holland Workmaster 120 (decoration?), Massey Ferguson 135 (does all the hay work)
I am new to ag, have sheep, and typically have fed them round bales in winter (well, the one winter I've had them so far...) I had to feed a bale this month due to drought. I have noticed sheep won't eat the entire bale...there's always a little at the bottom that's wasted. Problem is, this is enough to kill good grass underneath. What (if anything) grows afterward is weeds, not good grass. How can I easily get rid of this heavy, thick, and wet waste hay so that grass beneath isn't killed? I am trying simply turning it with a rake so it'll dry in the sun, then hitting it with a mower (I don't have implements for the tractor, yet, so using a riding mower.)
Going to have to reseed where bales were kept last winter. I don't have a whole lot of land, so can't give up good grassland because of this. Thanks for any helpful replies.
   / Round bales and cleanup #2
I've seen people suggest unrolling the round bale in a fairly bare part of the pasture. They still leave a lot of the hay; but the seed and organic matter help build the soil.
I was thinking about doing this with the round bale I fed earlier this month, but was advised against it due to waste. There's waste, anyway...so I might give it a shot if (God forbid) I have to feed another round bale this summer. I think an unrolled round bale would be easier to deal with than a piled up heap.
Praying for more rain.
   / Round bales and cleanup #4
Can you put the bale on a pallet, so the bottom spoilage will be reduced and the sheep will eat more of it?
Placing a round bale directly on the ground causes it to wick up moisture and spoil.
   / Round bales and cleanup #5
Oh, and I don't want to assume; But; any neting or artifical twine, make sure to remove and get out of the pasture, regardless of the feeding method. Only mentioned that, because you said this is only your 1st or second year, and it's one of those things, if you don't know; then you don't know; until your dealing with an animal with a belly full of poly twine...
Thanks paulsharvey and Hay Dude. I store my round bales on pallets...so sure...I'll throw a piece of plywood on top and put the bale on top of that (nails/screws coming out in hay = terrifying).
I pull the netting entirely off the bales I feed...yes, bad way for an animal to die.
   / Round bales and cleanup #7
The piece of plywood defeats the purpose. It’ll still rot on the bottom.
This wont happen with plastic pallets.
Even better would be to put the plastic pallet on top of some rock, but that may not be possible for you. Or you could double stack the pallets to increase air circulation.
   / Round bales and cleanup #8
When I feed steers I use a hay ring around the round bales (after removing netting. It keeps the hay contained and reduces waste because they can’t walk or urinate on it. These come in different configurations depending on the livestock being fed and they do have some styles designed for sheep and goats. Yes it will kill the grass under the feeder if the hay is there long enough, but it does contain the sacrifice area.
Got a particular style you prefer? These aren't cheap...some on Amazon don't look much differently constructed than their wooden counterparts.
   / Round bales and cleanup #10
You can usually find them for sale on CL or FB. They are also sold by chemical companies.
How many do you need? 2?
They are constructed completely different (at least the ones I have are) Mine are more like a mesh pattern, not wide flat slats. I have about 30 of them I collected over the years.
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
2016 Chevrolet Tahoe LS SUV (A48082)
2016 Chevrolet...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
2022 Club Car...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
