Roun & Round or Back & Forth ?
   / Roun & Round or Back & Forth ? #1
creeper
Amelia Va.
John Deere 790wFEL
As Im mowing I often have tried different methods ,mowing in a straight line then turning around and mowing the next lane seems to be the fastest way. I have also tried turning a constant circle and it seems like it takes alot longer. Any way just curious how most of you did it or if you ever think about it? My tractor is a gear jammer and it still seems quicker to turn around each time.
   / Roun & Round or Back & Forth ? #2
I'm not concerned about time, but I do like the look on the property when I go back and forth. Sometimes I just do big loops, but I prefer the back and forth method. I like to try to stripe the lawn.
   / Roun & Round or Back & Forth ? #3
Well, since I don't got a ZTR it's round and round I go, when I stop nobody knows. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Roun & Round or Back & Forth ? #4
</font><font color="blue" class="small">( just curious how most of you did it )</font>
I like to vary the pattern when possible, breaks the monotony and avoids leaving the tracks showing that you have if you mow frequently and the same pattern all the time.
   / Roun & Round or Back & Forth ? #5
I'm with Bird, and have read also that it's good for the grass to cut it from different angles. I go round and round some, the next time back and forth and the next time on a diagonal. I use this pattern with brush cutting and finish mowing both.
John
   / Roun & Round or Back & Forth ? #6
I like the way my wife cuts grass. /forums/images/graemlins/cool.gif I haven't cut grass in 15+ years and I'm happy with that too.
Don't know which way she cuts but it always looks nice to me. /forums/images/graemlins/tongue.gif
I sharpen blades,change oil, put on belts and pour the gas in. When I have it ready for her to use I tell her "let er rip tater chip". /forums/images/graemlins/cool.gif
   / Roun & Round or Back & Forth ? #8
Depends on your equipment and your property. Back when I was mowing as a side job and using my commercial walk-behind mowers, it was invariably back and forth. I alternated direction of the stripes 90 degrees each mowing; side to side one week, front to back the next. Some guys also throw diagonals in for a four week rotation. Keeps you from establishing wear patterns and just looks nice.
Now that I've dropped the mowing business, I use a JD garden tractor for mowing my own place. It would take forever to try to stripe everything, because of the big loop or three point turn at the end of each stripe. So now I compromise: the front part of my hill that is right in front of the house and easy to see from the road gets striped, even though it takes extra time. Everything else goes roundy-round, since it's quicker and the lawn there isn't good enough to show off striping anyway.
   / Roun & Round or Back & Forth ? #9
I cross-cut my main lawns - the others usually get the counter clockwise spiral treatment. /forums/images/graemlins/cool.gif
   / Roun & Round or Back & Forth ? #10
I'm a looper myself /forums/images/graemlins/smile.gif With my hills, sometimes there's not much choice in how I can mow...so I just do what's easiest - which is usually making circles until I get to the center.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
2014 Volvo Sleeper Tractor Truck (A52384)
2014 Volvo Sleeper...
2020 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2020 John Deere...
