ROUGH GROUND
   / ROUGH GROUND #1
karman 4564
Northwest pa,
johndeere
WHATS THE BEST WAY TO SMOOTH OUT GROUND THAT WAS MOWED WHEN IT WAS WET,THE PREVIOUS OWNER WOULD MOW TO EARLY IN THE SPRING AND HE WOULD LEAVE RUTS,I;M NOT TALKING JUST A FEW RUTS,BUT THE ENTIRE 6.5 ACRES IS ALL RUTTED UP,EVERY TIME I MOW I THINK I'M GOING TO LOOSE MY EYETEETH
   / ROUGH GROUND #2
Running a box blade over 6.5 acres would take a lonnnggg time. I have had pretty good luck removing ruts with a roller I made with Sonotube and Portland cement. The ground does have to be wet though.
   / ROUGH GROUND #3
Karman 4564:
Welcome to TBN :D! Smoothing out your rutted land would take a long time at the expense of your rear end and eyeteeth. EdC's suggestion could work if the ground was wet. You may have to consider having someone with a much larger tractor and a disc harrow doing this job :(. Jay
   / ROUGH GROUND #5
I've had success with disking the field and lightly dragging it.
   / ROUGH GROUND #6
for an area that large, disk it, then drag smooth....
   / ROUGH GROUND #7
I drug 8" wide flange I beam 8' long with chain key hole slots cut in each end hooked to small Leland 22hp tractor with chain this way I can adjust the I beam. It worked on the first 4 acres. When it hit a tree (many times) it would just slide off. Hope this helps.
   / ROUGH GROUND #8
a large heavy disc harrow will smooth it all out. You will then have to re-seed. I'd hire a guy with a harrow and grain drill, with tractor to pullthem, to harrow, then drill the 6.5 acres.
   / ROUGH GROUND
thanks for all the post.i decided to get a sprayer and roundup to kill the grass [weeds],then i'll use my landpride 2064 tiller and set it at the deepest rut[about 6 in]and smooth the field out this way,i know it will take awhile but i'll use it an excuse every time my wife wants to go shopping.then i'll just reseed it this fall.
   / ROUGH GROUND #10
If it has a good stand of grass, roll it to get the ruts out if they aren't really, really bad. Wait until the ground has some moisture but not real wet. The USDA in your area may have a roller to rent by the day. They have a couple that they rent out of our local office.
City of Lakeland (A51691)
City of Lakeland...
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
1987 FRUEHAUF 150BBL ALUMINUM TANKER TRAILER (A53843)
1987 FRUEHAUF...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2015 Skyjack SJ 4626 Scissor Lift (A53117)
2015 Skyjack SJ...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
