sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,744
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
Not wanting to upset the apple cart, as most people seem to be leaning towards the lighter weight mowers, due mostly to the limited TIME usage. I wonder just what the amount of time you use a mower has to do with what rating you purchase, other than to appease your pocketbook. If you plan on using a mower to do heavy duty stuff with, then you need a heavy duty mower. Using a light weight mower a few hours a week to do heavy duty mowing will still take it 's toll on the mower, as it is being used past it's design limitations. Granted you will be able to abuse a light weight mower for a long time but it is still abusing it.
Once you get the roughest stuff cut, the more often you mow, the easier it will be on the mower, so it you really do have "heavy duty" stuff to cut, then hire it out the first time and then use the light weight mower to keep it cut. If your mowing requirements aren't really heavy duty cutting, then all we have done is wasted a little bit of bandwidth.
If you decide to go with the lighter duty mower, then take it easy on it for the first couple cuts (read GO SLOW!!) and you will probably be ok. Lord knows I have abused many a bush hog and they have lived to mow another day. Last one I destroyed was with a bunch of 3/8" diameter guy wire that the power company decided to throw into the bushes on some property I mow for the church. I knew I was in trouble when it stopped the 70 horsepower tractor dead in it's tracks.
David from jax
David from jax
