Rototilling
   / Rototilling #1
SouthernX
I have a NH 2420 (60HP) tractor. If I pulled a 6' rototiller behind it at a 5" depth, how many acres in an 8 hour period could I expect to get tilled?
   / Rototilling #2
Here is a formula I found from Iowa Farm extension service. The field efficiency if a factor of how long the distance is before you have to stop and turn around and lower implement and start tilling again. Obviously if you only go 100 feet and turn your efficiency is going to be low whereas if you go 1/4 mile you may get 98% efficiency. I believe the recommended speed for tilling is about 2 mph with 3mph being about the max you can expect if in softer soil. The harder the soils like hard clay for instance, the slower you have to go.
field capacity = width X speed X field
efficiency DIVIDED BY 8.251
For example, assume a 24-foot
tandem disk can be pulled at 6 miles
per hour with a field efficiency of 80
percent. Its estimated field capacity is:
24 feet  6 mph  80%  8.25 =
14 acres per hour
   / Rototilling #3
There is lots of other interesting reading on HP requirements, field days needed to do certain amount of work etc. check out this site or just Googlesearch for "horsepower requirements for farm implements" and you will get several hits.
http://www.extension.iastate.edu/Publications/PM952.pdf
   / Rototilling #5
Inches of working width X MPH , then divide by 100 = per hour
ie, 72" tiller with some overlap, let's say you'll be working 65" for arguements sake. Let's use a nice round number of 1 MPH.
65" X 1 = 65. Divide by 100 = .65 acres per hour. 8 hours, you can expect 5.2 acres.
   / Rototilling #6
So 2 MPH (3.2 KMH) would be about 10 acres in 8 hours and that sounds about right to me
   / Rototilling #7
Ouch! 8 hours on a tiller? That sounds like a long day to me.
   / Rototilling #8
With a 5' tiller (cuz that's what I have)
it's 1/2 acre per hour
or 1 acre every 2 hours
so, the above with 5 acres in 8 hours with a 6' rings true for me.
   / Rototilling #9
How fast will you go? :D
Exactly.
When I rototill my veg garden with the 14 hp Bolens G14 garden tractor and a 32" wide rototiller, I don't move more than 1 mph and make several passes to get the tillage I want.
When I installed my landscaping around the new house 3 years ago I used a 48" wide Yanmar RS1200 rototiller and the Kubota B7510HST (21 hp engine). I moved probably 0.5 mph then because the ground was pretty dry and hard and the rototiller skipped along the surface if I tried to increase the speed. Hydrostatic transmissions are what you need for rototilling in these conditions.
The OP needs to specify the soil condition and the amount of tillage (coarse, medium, fine) he needs before his question can be answered more precisely.
   / Rototilling #10
The problem that you will find is that the calculations are for pristine field conditions.
When I tilled my 7 acre field last year it took a several days of getting on and off the tractor and picking rocks and putting them into the FEL bucket.
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
