Rototiller for JD 4110
   / Rototiller for JD 4110 #1
gcrider
ohio
JD 4110
I figure I should get a 48 in tiller. Is that correct. What kinds are good and heavy duty? Any other advice is appreciated.
Gary
   / Rototiller for JD 4110 #2
A lot of people are using King Kutter. I use a Bush Hog, and I like it. Either one will work fine for you.
48 inch tiller is the right size for you.
   / Rototiller for JD 4110 #3
With my limited experience, consider width (cover rear tire tracks), weight (heavier is better) and service (parts availability). Another good source for information and pricing is Tractor Ground Engaging Equipment . I can recommend the Ansung (Terraforce ) My YJR074 ids built like a tank.
The other thing is try and rent the unit your considering so you can be sure it is a good match for your unit. Sometimes you can go bigger and wider than the HP recommendations say depending on the soil type and your tractor. I actually went to a larger size after trying a smaller recommended unit out.
Hope this helps
   / Rototiller for JD 4110 #4
Best bang for the buck is the KK48, the Deere 647 is another good choice.
   / Rototiller for JD 4110 #5
You can check out the 48" King Kutter XB series tiller on our website. They're made for subcompact tractors exactly like yours. The 48" Phoenix tiller is another great choice. We offer free shipping to a business or supporting freight terminal within 1,000 miles of Newton, NC and we also have product videos on our website for each of those tillers.
   / Rototiller for JD 4110 #6
Wonder if there is a rule of thumb on hp for size of tiller? Seems that with a bush hog people say 5 hp per foot is a good rule, but what about other implements?
71061 (A49346)
71061 (A49346)
2018 Hyundai Elantra Sedan (A48082)
2018 Hyundai...
19010 (A48082)
19010 (A48082)
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2013 John Deere 608C Corn Head (A50657)
2013 John Deere...
