Rotella T(6) 5W40 in your tractors.
   / Rotella T(6) 5W40 in your tractors. #1
dieselfreak
Ontario, Canada
Hey,
Curious if you guys (and Gals) are riuning Rotella t6 5W40 in your diesel tractors? When did you switch out, and are you running it year round?
Thanks,
df.
   / Rotella T(6) 5W40 in your tractors. #2
My Mahindra 3215 uses Rotella T 15-40
   / Rotella T(6) 5W40 in your tractors. #3
I use rotella 15/40 in my Kubota and change it every year regardless of the hours. I may have skipped a year once or twice in 10 years in a very low hour year to be honest.
   / Rotella T(6) 5W40 in your tractors. #4
I've waited until I had a few hours on my machine, but yes, I intend to use the Rotella. Either the 10w-30 Silver jug, semi-synthetic, which I got for $16 a gallon a few weeks ago, and I may very well try that 5w-40 as well. Yes, I'd run either year around. Saw that yesterday for $19.50 a gallon.
With our cold winters, 15w-40 isn't going in my machine, as I will only change the oil once a year, (60-70 hours) on average. I might also be curious to try the Deere synthetic, as I understand it is reasonably priced.
An oil post. What could be a rarer thread and draw less debate? :laughing::laughing:
   / Rotella T(6) 5W40 in your tractors. #5
Been using Rotella 5w40 for some time now. use it summer and winter. I have had no problems at all. I was useing Mobil one diesel until it just got to expensive.
   / Rotella T(6) 5W40 in your tractors. #6
I do the same, changed from M1 turbodiesel, got hard to find AND too pricey, change once a year, run it in my gas engines and cars and all diesels... KennyV
   / Rotella T(6) 5W40 in your tractors. #7
I use Mobil 1 0w30. The JD manual calls for 5w30 being okay. This is one step better. Use this in all my engines now except for the new VW TDI. It requires Mobil 1 ESP, but we have 3 years of maintenance included. So, the dealer will be putting their Castrol SLX 5w30 in it for the first 2 oil changes at one year or 10k miles.
Why wouldn't you use 5w40 year round? It's 5w on startup and 40 weight when hot. In the old days, they used 20w in winter and 30w in summer. This is lots better.
Ralph
   / Rotella T(6) 5W40 in your tractors. #8
Ditto on the Rotella T 5W40 for me (in my tractor).
   / Rotella T(6) 5W40 in your tractors. #9
I used Shell 5w40 for years in the truck and tractor. The oil really was nice on those cold mornings. The truck did not need to have the block heater anymore. I did get 1-2% more MPG.
Switched to the JD 0x40 oil in a 5 gallon bucket. When I switched the JD oil was $100 or $20 a gallon. Shell was $25 a gallon.
Got another 1-2% MPG. Staring on cold mornings the engine just does not care. Before it idled real rough. It would start up but it sure was not pretty.
I started using the JD oil since it is a bit better but cheaper. If the JD oil is goes up in price compared to Shell I would go back to Shell. Both are more than good enough for my uses.
Later,
Dan
   / Rotella T(6) 5W40 in your tractors. #10
I use it in everything I hv also, I switched to it in my Bobcat at the 50hr service. Samething in the winter it wouldnt start at 0* but when I switched it turned over like it was 80 out. I use it in my dmax truck and my Canam outlander atv. Nice havin one oil on the shelf now.
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
2020 Sellick S80 (A50123)
2020 Sellick S80...
