Rotella 10-W30 ok for BX2200 Kubota D905?
   / Rotella 10-W30 ok for BX2200 Kubota D905? #1
r0GuE
Veteran Member
West PA
ex-Bota Owner
I really needed to get an oil change done yesterday. I stopped at Advanced Auto and the only oil they had in the diesel section was Rotella (from Shell) in 10W30. They had other brands in other weights. The oil didn't SAY diesel but had a CJ-4 rating which seemed based on my web searching to be about the called for CC or CD oil.
I'm here just looking for some reassurance or redirection as to whether I'm ok, or need to change it to something else. Thanks!
This is what I got:
http://shop.advanceautoparts.com/we...google&utm_campaign=value3&utm_content=value4
   / Rotella 10-W30 ok for BX2200 Kubota D905? #2
I've been using the same stuff in my NH tractor for over 5 years.
   / Rotella 10-W30 ok for BX2200 Kubota D905? #3
If it calls for CC or CD and all you have is CJ, you are good to go. Just make sure you are using the 2nd letter called out or higher. Since the letter J is higher than C or D, you have no problem using it.
Tom
   / Rotella 10-W30 ok for BX2200 Kubota D905? #4
Tom
I'm putting Rotella in mine, but the 15-40 wt variety.
2011 Ford E-350 Passenger Van (A46683)
2011 Ford E-350...
2017 Dodge Ram 1500 Crew Cab Pickup Truck (A46684)
2017 Dodge Ram...
Ford 8N Tractor (A49251)
Ford 8N Tractor...
2011 Ford Fusion Sedan (A46684)
2011 Ford Fusion...
2015 Nissan Rogue Select SUV (A46684)
2015 Nissan Rogue...
New/Unused Pallet of 5 Binder and 10 Chains (A48837)
New/Unused Pallet...
