Rotating seat for backhoe use?
   / Rotating seat for backhoe use? #1
Ken P
North Granby, CT
Kubota B2410
Folks - In looking for my first tractor, I've noticed that the Kubota's have a rotating seat for using the backhoe. Do any others have this feature, and for those that have it, how useful is it?
Storage space is going to be a real problem for me - I'd like to be able to store whatever I get in the garage, but space is tight. If the rotating seat works well and really does lessen the overall length of the tractor, it might be a real plus.
Thanks -
Ken in North Granby, CT
   / Rotating seat for backhoe use? #2
Thanks -
Based upon that statement I believe that you are essentially comparing two different styles of backhoe. The backhoes that have an additional rear facing seat are generally backhoe attachments that go onto a tractor. Backhoes like the Kubota M59 for example are basically more dedicated TLB's (Tractor, Loader, Backhoe). Even though the M59 for example can detach the backhoe and use 3 point hitch implements it really is a different animal (and a fair amount more expensive) than say a Kubota 4240 or a New Holland Boomer with subframe backhoes attached. I believe just about all of the subcompact tractors have a way to flip over the seat so as to use it with a backhoe attachment because there is not enough room to have a swivel seat and a backhoe attachment with the seat attached would probably put too much weight too far behind the tractor. If you are going to use the tractor primarily for digging then a dedicated TLB may very well be a great investment for you. However if you plan on using the tractor more for mowing, tilling, plowing, with occasional use for digging reasonable depths and reasonable size areas then my guess is you could probably accomplish all those things with a standard compact or subcompact tractor with a collection of implements including a subframe backhoe for less money than what a dedicated true TLB would cost.
Oh and to answer your question about swivel seats, they do come in handy. I've used full size bachoes (Ford and NH 555's and NH LB75.B) that had swivel seats and I found it to work better than a flip over seat. They are especially handy if you have to reposition the unit a lot.
   / Rotating seat for backhoe use? #3
I occasionally use the backhoe of my B21 by turning sideways in the seat without rotating. Doing so for long periods of time starts to stretch stomach muscles and becomes painful. I am much more efficient digging when I am comfortably rotated. In my opinion the ability to rotate or flip the seat is very important.
I believe some larger TLBs allow you to rotate the seat while seated. I dismount the tractor, rotate the seat then climb in the rear facing seat.
   / Rotating seat for backhoe use? #4
And here I though that flipping over the seat in my JD 110 TLB was a PITA. At least I can do that without dismounting, but then climbing over the seat I just flipped is a real adventure.
   / Rotating seat for backhoe use? #5
I should mention that in the full size backhoes that I used with swivel seats, you were able to remain seated while you swiveled around in all of them. From the looks of it you may have enough room to do so on the Kubota M59 as well.
I appreciate the responses. I meant that the swivel seat would be a plus for Kubota vs the other brands; I am looking at CUTs only. It wasn't clear to me from the other manufacturer websites that their seats rotate. It looked from pix that I saw that the backhoes mostly came with an extra seat. Do all the CUT-class seats rotate, or is it brand-specific?
Apologies in advance for showing my newbie-ness-
Ken
   / Rotating seat for backhoe use? #7
Ken,
I believe that most 3 point mounted backhoes have a rear facing seat built into them as they do not expect the tractor to have a rotating seat.
Here is an example
Some TLBs have frame or submounted backhoes. This is an example of a Kubota B21
The frame mounted backhoes are much more securely mounted. Personally I prefer a frame mounted backhoe. I have read several stories of cracked rear ends from using 3 point mounted backhoes. Using a backhoe places huge stresses on the tractor, the FEL and the backhoe mount points. I a worst case scenario part of the 3 point linkage might fail and allow the backhoe to tilt either throwing or crushing the operator.
I suggest the advantage is not that the seat swivels but that a TLB designed to have a backhoe typically has a much stronger backhoe mount. An additional advantage may be that the TLB was designed to have the correct hydraulic flow to operate the backhoe.
In this picture I have circled the four attachment points for the B21 backhoe. You can see that they are much stronger than the 3 point hookup seen above.
How are you going to use your tractor? My B21 would not be very good hauling hay or bush hogging hundreds of acres but it is much better than our farm tractors at clearing roads, digging trenches and moving dirt.
   / Rotating seat for backhoe use? #8
The newer, smaller backhoe set ups on Kubota's do use swiveling seats. I'm talking here about the BX, and B series tractors. I think it does help keep the backhoe more compact, closer to the tractor for better balance, and leverage. A side benefit would be the reduction in storage space required. JD, and other brands are still using separate seats on their sub frame mounted backhoes.
   / Rotating seat for backhoe use? #9
I personaly would not make the swivel or non swivel seat a major part of my decision making process.
For example, my backhoe is frame mounted, very similar to Kubota, but I have a separate seat.
Would be surprised if my machine is much if any longer due to the separate seat.
Decision must first be based on capacities and the like, if dimensions are good but capability is not there then you are stuck with a machine that will not suit your needs.
Joel
I think I'm getting the idea now. I wasn't intending to use the seat as a huge point, but it will make my life easier if the tractor is a bit shorter, so if all else was equal, I thought that the second seat might make some difference to a decision.
Bruce, I intend to use the tractor for a variety of landscaping stuff, kind of a little of everything. I picture using the backhoe to dig holes for planting trees, to dig out unwanted stuff (like invasive vine roots), and so forth. Basically, to do the sort of things I might be able to do by hand if I was 25 years younger and had a LOT more free time and didn't care if my back hurt for 2 weeks afterwards. Thanks for the pix, that helped a lot.
Ken
2012 Ford Expedition XLT SUV (A44572)
2012 Ford...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A42742)
2025 Kivel 48in...
2000 Ford E-350 Super Duty (A44501)
2000 Ford E-350...
Rolloff Dumpster (A42742)
Rolloff Dumpster...
2012 Sun Coast 12ft Enclosed S/A Trailer (A42742)
2012 Sun Coast...
2016 Ford F-550 4x4 Altec AT40M 40ft Material Handler Bucket Truck (A42742)
2016 Ford F-550...
