Rotary plow with 8 hp unit
   / Rotary plow with 8 hp unit #1
vdeal
WV
Case 1290, BCS 720
Earth Tools' website notes that the Berta rotary plow will work on BCS and Grillo walk-behind tractors that have at least 8.5 hp (gas). My question, "has anyone used a rotary plow on an 8 hp gas engine tractor?" I would be using the plow on ground that has been plowed with a moldboard plow by a large tractor, disced and rotary tilled. Eventually I reseeded the area but I know the condition of the soil and it's in good shape. This is a theoretical question at this point because it would probably be next year before I could do this. Buying a plow and a larger tractor are not really in the equation thus my question. I do know that I would need to upsize the tires but that is doable. Any feedback would be appreciated.
   / Rotary plow with 8 hp unit #2
If it's the Kohler Magnum. Yes. If it's a Briggs or Honda. Probably not. I used to mow my my lawn with a Kohler Magnum powered 730 on the 38" mower. Joel said it shouldn't do it, but it did. Those Magnums were a great engine with lotsa torque.
I have the Briggs & Stratton Industrial Pro. Still curious if anyone has done it.
   / Rotary plow with 8 hp unit #4
I think the big issue with 8hp powered two-wheel tractors is that they usually do not have differential drive to the wheels nor have the larger 5x10 wheel and tires. The lack of the differential make turning much more difficult especially if you fit the required 5x10 wheels and tires and the wheel extensions required to give the tractor 16" of width between the tires measured inside to inside. My advice is get a larger tractor with differential drive, even a BCS 830 with the 8hp Kohler Magnum.
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2015 Case 580N EP Loader Backhoe (A53117)
2015 Case 580N EP...
2021 John Deere 1023E Tractor (A52384)
2021 John Deere...
1269 (A50490)
1269 (A50490)
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
