Rotary Cutter rotary cutters for heavy brush:
   / rotary cutters for heavy brush: #1
Crutches
North Florida
Kubota L3600
I have a 40hp Kobota tractor. I need a rotary cutter for heavy brush, small trees and some grass cutting for 40 acres of land. I am looking at the Rhino CY60 and the Bush Hog 305. These are five foot cutters. Which would be better and is there another model or brand that would be a better choice?
   / rotary cutters for heavy brush: #2
I would say go for the Bush Hog. From what I have heard from my area seems to be a better cutter overall! /forums/images/graemlins/grin.gif
   / rotary cutters for heavy brush: #3
I would go with the Rhino -- they make excellent mowers.
The Rhino has a better gearbox. The Rhino also has a faster blade tip speed which should give a better cut. There is nothing wrong with the Bush Hog if you decide to go that route.
   / rotary cutters for heavy brush: #5
Since both cutters are very near equal, I'd price shop this one.
I think you'd be happy with either choice.
   / rotary cutters for heavy brush: #6
40hp tractor? why you foolin' around with a 5' cutter that a high 20ish hp tractor could handle?
You should be able to power up a 6' and have plenty of power left over to ring out a few shear bolts pretty darn easilly...
Soundguy
   / rotary cutters for heavy brush: #8
I like mu older Servis CY72, but watch the weight if your looking at a 3pt model instead of pull type. I got mine from a guy who traded his JD utility for a TC35 and said it made steering an adventure with the Cyclone mounted. HD cutters are heavy and the weight is well aft of the tires.
   / rotary cutters for heavy brush: #9
Crutches,
Are you planning to mow your 4 acres once, twice, or half a dozen times a year?
When I cleared my 10 acres, I thought I needed a heavy duty brush hog. I didn't foresee the fields ever being tamed. But now, all I really need is a finishing mower.
If you could get rid of the bad brush 1 time without buying a cutter, then all you would need would be a light or medium duty. Your tractor will probably just pull a 5' HD cutter, but will pull a 7' standard duty. With 40 acres to cut, I think I would be looking for WIDTH! /forums/images/graemlins/laugh.gif
The routine cutting for the three acres is to cut fern. The forty acres is quite a job. I am getting a front end root rake to dig some palmettos and small trees also.
2013 Hyundai Azera Sedan (A50324)
2013 Hyundai Azera...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
