jgbanshee
- Joined
- Sep 16, 2004
- Messages
- 316
- Location
- PA
- Tractor
- JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I just bought a John Deere 503 5" rotary cutter to pull behind my Ford 2N. When I raise the 3pt hitch while using the mower, the pto shaft hits the top corner edge of the mower. Is this common? Is there anything I can do? As of now I can only raise the 3pt hitch to max when the pto is disconnected. Is there tricks to using a rotary cutter with an N that I should be aware of? Thanks.
