Mowing Rotary cutter size for B7500?
   / Rotary cutter size for B7500? #1
santurinos
South-West Georgia (Buena Vista)
Kubota B7500
I need a rotary cutter (bush hog) for my Kubota B7500. Is this tractor capable of handling a 60 cutter or should I buy a 48 deck?
Thank you folks have a nice day Santurinos.
   / Rotary cutter size for B7500? #2
We sell the 38, 42,48 inch Big Bee for $795. Ken Sweet
   / Rotary cutter size for B7500? #3
Two factors determine rotary cutter size. HP at PTO and if you'll just cut high grass on level ground or high growth with small trees.
Answer those two questions and I'm sure you'll get an answer concerning the size Rotary cutter you should buy.
   / Rotary cutter size for B7500? #5
   / Rotary cutter size for B7500? #6
48, is what I used, when I had one,and that is about all you need to have back there. I am not saying if all you cut is short grass on level ground, you could not use a 60 but if it involves hills and saplings, then 48 for sure.
James K0UA
   / Rotary cutter size for B7500? #7
I just bought a 48" Rotary cutter from Barlows for my B2320 geared 23HP not sure PTO HP but Dealer knew. Steve Barlow said that was the size for me to buy between the 48" and 60", he had both sizes for sale.
I don't know the HP of your tractor but I guess others do.
Thank you JohnThomas (and everyone else!) for your helpful contries.
I have plenty of high grass, previously cut with a rotary cutter. BUT... I have a few places with small trees and bushes.
(Everything grows wonderfully on our farm except fruit trees, roses, vegetables...)
I consider a CountyLineョ Rotary Cutter, 4 ft at TSC, I could get it locally (Columbus GA) for about $850.00 plus tax.
   / Rotary cutter size for B7500? #9
48" would be the biggest I would go on a machine that size, rotary cutters are heavy.
-Mike
   / Rotary cutter size for B7500? #10
You should seriously look at 48 inch flail mower from Ken Sweet or a Caroni flailmower with a B rotor from Agrisupply for your type of brush cutting and maintenance.:thumbsup:
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
