Rotary cutter / shredder for Kubota L3200
   / Rotary cutter / shredder for Kubota L3200 #1
rarvesen
Central Texas (Texas Hill Country)
I have a Kubota L3200 and looking into getting a rotary cutter. I live in central Texas and this will not be used on a rock free field of grass, rather mowing down overgrown weeds.
I have never had a rotary cutter before. What happens if you do hit rock, is there a good chance the cutter and / or tracor will be damaged?
Are there cutters you would recommend? I assume the Land Pride RCR1260 would not be a good fit for this environment, do you think the Land Pride RCR1860 would be sufficient? I appreciate any information, thanks.
ralph
   / Rotary cutter / shredder for Kubota L3200 #2
I think most will do a good job. I use a Rhino 160 since that is what the local dealer was selling. Rhino also makes a 260, which is a heavier unit. Because the blades pivot, generally you end up just beating up the cutting edge and need to resharpen and replace blades more often. My main recommendation would be the use of a driveline clutch instead of shear pins. Several mowers come with them as standard equipment. If not they can be purchased separately at dealers or Tractor Supply.
   / Rotary cutter / shredder for Kubota L3200 #3
Use a PTO clutch IF you service it every year.Not hard to do about fifteen minutes after the first time.I have a clutch on my tiller,my BH has shear pins and have only broke three in 700 hrs of cutting.I have lots of rocks.
   / Rotary cutter / shredder for Kubota L3200 #4
I have the RCR1860 on my L3200 and it's perfect for smooth cuts or heavy brush cutting. Also it came with the "slip clutch" so I'm not constantly worrying about replacing those shear pins.It's a well built rotary cutter and fits well on my L3200.
2003 Lincoln Aviator (A50515)
2003 Lincoln...
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
Wolverine Quick Attach Rock Rake (A50515)
Wolverine Quick...
5' X 20' 3/8" THICK STEEL PLATE (4) PIECES (A51244)
5' X 20' 3/8"...
