Rotary cutter repair
   / Rotary cutter repair #1
coltbean
Conway ar
Kubota L2501 4x4 HST
My land pride rcr1860 has some slopnin the tail wheel yoke spindle. Anyone know the pipe ID? What hardness or type of pipe should I use to replace it with?
   / Rotary cutter repair #2
Most likely you'll find both the I.D. of the pipe and the O.D. of the spindle worn to some extent and both might need attention to tighten it up.
   / Rotary cutter repair #3
That particular joint is tolerant to considerable play. A good moly grease applied frequently helps.
2” brass shim stock0.010” Wrapped around the shaft top and bottom might extend the life before replacement is needed. Sometimes a washer top and bottom helps tighten vertical play helps too.
I’m all for making them last.
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
Curt Receiver Hitch (A51573)
Curt Receiver...
20711 (A50323)
20711 (A50323)
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
