Rotary Cutter Rotary Cutter Maintenance
   / Rotary Cutter Maintenance #1
BB_TX
Veteran Member
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
Time to start mowing again. Turned my cutter up on it's side to sharpen the blades. Found they were "frozen" to the stump jumper as usual. Each spring I find that they have accumulated grass, dirt, baling string, etc. and rust from sitting over the winter so that the blades do not swing freely as they should. After soaking in penetrating fluid, WD40, and finally gear oil, and using more than a little muscle /forums/images/graemlins/frown.gif, they were again swinging freely. Good idea to make sure yours are free as they are designed that way to take some of the shock out of hitting large objects.
International 820 Platform (A50514)
International 820...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
3 phase 175 psi air compressor MI- T- M (A50322)
3 phase 175 psi...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
Toro Z-Master 6000...
