Rotary Cutter for MX5000?
   / Rotary Cutter for MX5000? #1
Britt
Maryville, TN
Kubota MX5000
I purchased a MX5000 this past weekend and I'm anticipating delivery soon. I need some advice on choosing a rotary cutter / bush hog for this tractor. I have some rough land to reclaim but I don't want to spend $1500 on a new heavy duty bush hog. I'm looking at brands King Cutter, Bushhog, Hawkline, Woods. Any suggestions? Also do I need a clutch or is the shear pin enough, and what is the additional cost for the clutch? I appreciate any feedback.
/forums/images/graemlins/cool.gif
Thanks.
   / Rotary Cutter for MX5000? #2
The slip clutch is only good if you do the maintenance every so often to unstick it. Are there big stumps and rocks? Changing shear pins gets old fast.
Will you need to cut often? Buying a cheap one that gets ruined after one season isn't a good idea.
Ken
   / Rotary Cutter for MX5000? #3
A friend of mine bought a Bush Hog squealer 6' rotary for reclaiming 6 acres of open land that had gotten away - 2" poplar and soft maples mixed in with 3" field pines. It was pretty brutal and the mower's stump jumper (elliptical) got twisted. He borrowed my Brown 472 to finish it up - which was heavy enough to handle it without damage.
The Brown is virtually identical to a Bush Hog 286 - made heavy. I'd suggest going heavy for "reclaiming". Another advantage of a heavier unit is the higher rotating mass makes it a bit less likely to do drive train damage if you hit a rock. Once you spin it up, the cutter delivers the hammer blow and the tractor gearing takes less impulse.
Slip clutches were more common years ago - but their faces tend to stick if not occasionally "slipped". They can get so stuck in place that they don't offer the intended protection. I have had good luck with soft bolts in the pto shaft (from the local hardware store) - they wipe off pretty reliably if the going gets rough. Your MX5000 would probably be adequately protected with a 1/2" soft steel bolt thru the rear pto u-joint. I've had good luck with this setup for years. If you wanted to be more conservative, use a 3/8" bolt with some copper tubing around it to fill the gap. (might occasionally shear in nomal service)
As always, cheerful refund if info is bogus. /forums/images/graemlins/smile.gif
Thanks for the good input. The cutters generally come in light duty, standard duty and heavy duty. I have a lot of rough land with stumps and 2"-3" young pines, so I may better find a good heavy duty or a heavy built standard duty. I'm leaning against the slip clutch - if I see a big advantage later, I'll add it.
If anyone has some brand or model recommendations, I'm all ears.
Thanks.
Britt /forums/images/graemlins/cool.gif
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
2011 MCI D4505 TANDEM AXLE PASSENGER BUS (A45679)
2011 MCI D4505...
2020 CATERPILLAR 988K WHEEL LOADER (A50458)
2020 CATERPILLAR...
2019 HINO 155 16FT BOX TRUCK (A50046)
2019 HINO 155 16FT...
2014 KUBOTA R520ST WHEEL LOADER (A50458)
2014 KUBOTA R520ST...
2025 Swict 66in Bucket Skid Steer Attachment (A49346)
2025 Swict 66in...
