Rotary cutter bladt tip speed?
   / Rotary cutter bladt tip speed? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
This has just become an eye opening spec to me after using a borrowed tractor/mower...
We used a 7' mower so for no other reason than that, I using for my example below, HD 7' mowers of these brands...(my real goal is to get a 15')
Woods 8400 7' HD mower, BTS 16,000 fpm
Bush Hog 307 7' HD mower, BTS 11,875 fpm
Brown 684, 7' HD mower, BTS 17,803 fpm
I presume these all use a 540 pto, so given their input could be the same tractor, is one able to make any conclusions based on fpm alone?
Pros/cons?
1. Would the Brown mower be better in "grass" since it has a higher bts, or is it the opposite and the Bush Hog would be better in "grass"?
2. Seems to me, this is all done via gearing, as such, I'd expect in thick stuff, the slower bts to have more power behind it so it wouldn't bog down?
When one is looking at a mower, is this the first spec you might want to look at, after size & duty rating?
I never ever thought about bts, I always presumed for a given size, they'd all be the same.
The Brown we borrowed... while using it, one thing I noticed that is now clear (given it's bts)... it really chopped things up. When I ran over sapplings, small cedar trees... they simply came out the other side as toothpicks. VERY unlike our cutter on our IH-444. Had I run over the same items, those items would have shaken that cutter to smithereens and come out the backside as hacked up stalks, instead of shards.
While cutting I started to get the gut feeling that this mower was cutting MUCH faster (bts) than our cutter, but frankly, I attributed that to the IH-444 probably not getting up to PTO speeds on the tach (old & tired) and the NH we were using being fresh & strong.
Now, I realize there was more going on with the gearing of the cutter themselves.
I'd love to learn more about the pros/cons of BTS when used on same sized mower/tractor.
   / Rotary cutter bladt tip speed? #2
Oh boy, this could get interesting.
The BTS will affect the quality of your cut. On grass with a lawn mower, faster BTS usually gives a nicer cut for three reasons -- an effectively slower "feed" rate (there are more mower blade/grass blade impacts per unit of forward travel), more "lift" pulling the grass up into the blade, and more velocity applied to the cuttings to throw them out of the way of the cutting action. With heavier stuff, you will get the first and third benefit, but the second one is not of much consequence.
Having a lower BTS will increase the amount of torque acting at the center wheel of your mower, but whether or not this will translate to more force at the tips of the blades will be a little confusing. The faster turning center hub will give more momentum to the blades and more "centrifugal force" to keep them radial, but there will be less force turning the base of each blade when it hits something substantial. I'll let someone else do the math to figure out the optimal relationship between blade RPM and horsepower.
You also have to consider the potential damage caused when a blade hits a rock or other object. Will a faster turning blade tend to shatter quicker than the same blade moving slower?
I would tend to go with a faster mower for grassier areas and a slower one for brush, saplings, and other truly rough cutting jobs, but that's primarily a gut reaction.
I've never heard of Funk, but I'm originally from Hamilton, near Cincy.
   / Rotary cutter bladt tip speed? #4
Funk is about 1.5 miles west of Blachleyville and 6 miles north of Big Prairie. We have a general store/gas station/sheriff's outpost/deer checking station, an Amish sawmill, and about a dozen houses in town. I live in the 'burbs. :)
Sounds MUCH like where I live now, in "Greenback" :D
   / Rotary cutter bladt tip speed? #6
For brush cutting.. and 'mass' pasture maintenance.. like a 10 or 15 or 20' mower might be doing.. first 2 things I look at are price and durability.
Heck.. I have a 15' mower.. and don't know the BTS.. never looked it up.. don't care.... It knocks saplings and brush over fine. Just happens to cut pasture grass and briars as well.
If I owned a golf course.. I might check the BTS on my 'finish' mower... but for a rough cutter that doesn't even use sharpened blades.. i think BTS is more like 'chrome'...
Soundguy
Pros/cons?
   / Rotary cutter bladt tip speed? #7
Pros/cons?
Those Brown mowers are considered to be about the best there is at handling REALLY tough mowing conditions. I thought it was interesting it has the highest blade speed.
I'm all the time telling people how my Bush Hog 286 cutter cuts "cleaner" than my Woods BB840 or the old Woods MD172 I had. Then I see Bush Hog with the slowest blade speed. Interesting also.
I'm comparing totally different models too.
   / Rotary cutter bladt tip speed? #8
For higher BTS, the damage to the equipment might be worse when you hit a buried steel pipe, large rock, stump etc. It would sure have more whacks before the clutch could be stomped or the 3pt raised.
It probably has a greater hp requirement (torque really) to get the blades up to speed and keep them there. It's like being in 5th gear vs 4th gear. The engine might bog down easier in heavy weeds, but if you start with a big enough tractor...no issue.
I did try and maximize several things when buying my last cutter. BTS was one, gear box HP capacity, overall weight and stump jumper weight the others. I wanted the greatest rotating mass, to dampen the shocks of hitting and cutting a larger tree.
It does sound like Richard got his own questions answered. For his application, higher BTS seems to make the equipment perform better.
jb
Anybody know if we put a conveyor under the mower with the highest BTS, if it would take off or not?
:p
   / Rotary cutter bladt tip speed? #10
Seems to me if the blade is turning faster and has the torque to go with it, it should cut anything (that will cut) better than a slower blade with the same amount of torque-
With that being said, what about the gearbox and the ratings? Is the Brown BTS based on 120HP which is what the gearbox is rated at? Is the BTS slower with a 65HP tractor at 540rpm than with a 90hp tractor at 540rpm?
Farmwithjunk - your BH286 BTS is rated at 14,877
"For higher BTS, the damage to the equipment might be worse when you hit a buried steel pipe, large rock, stump etc. It would sure have more whacks before the clutch could be stomped or the 3pt raised. "
Johnbud - Is this true if the slipclutch is properly adjusted?
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
2015 KENWORTH T800 HOT OIL UNIT (A53843)
2015 KENWORTH T800...
Miller Deltaweld 452 Welding Machine (A53117)
Miller Deltaweld...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
