Canopy ROPS O/D Dimensions MT240?
   / ROPS O/D Dimensions MT240? #1
Aavantaggio
Midcoast Maine
LS MT240HE FEL
Does anyone know what the outside dimensions of the tubing on the ROPS on a MT240 are? I’m waiting for delivery on mine and would like to fab some clamps for it. Trying to see if I can get away with rectangular tubing will work or if I’ll have to mill it from aluminum rectangle stock. Thanks in advance.
   / ROPS O/D Dimensions MT240? #2
No idea, but I suggest you wait until you have the machine and can custom fit things as needed.
Makes sense, thats the plan, I'm just trying to see what I'd be looking at for pricing of material. Rectangular tubing is available in 2"x3", but stock only in 3"x4". Curious if the 2x3 will work or if I'll have to go with the 3x4 and mill a bunch off.
   / ROPS O/D Dimensions MT240? #4
The dimensions are 1.80 inches (45.25 mm) x 2.96 inches (75.03 mm). Hopes this helps you out. What type of brackets are you going to make? For what use? Just curious....
I was thinking about making some sort of a bracket to hold a string trimmer/brush saw on the back. Brackets similar to the ones you can buy online but I have access to a milking machine so I though I’d try it myself. Thanks for the dimensions. Just got the tractor today!
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
