ROPS mounted Additional Lights for 2305?
   / ROPS mounted Additional Lights for 2305? #1
inspectorman
Greetings all! Have had my 2305 for about 5 days now and got to put 10 hours in already. Amazing how much you can get done (and how much you can find to do) when you have a tractor!
Was wondering does anyone know of a manf. that makes a ROPS mounted light kit for additional lighting? Figure with some better lighting I could work in the dark too.
   / ROPS mounted Additional Lights for 2305? #2
Hi:
The light kit that JD sells attach to brush guards that go over the warning lights. They work pretty well but if you turn around they can blind you.
If you didn't have a canopy you can clamp or weld a little tang. (I welded one on the top of my ROPS for my rear work light).
The JD ones are 35 watts and are pretty bright. You won't require a larger alternator either. I run two 35 watt forward lights and a 55 watt work light (and the stock lights) all at the same time and you won't discharge the battery.
   / ROPS mounted Additional Lights for 2305? #3
Do a search on rops lights :
All kinds of ideas and suggestions there.
   / ROPS mounted Additional Lights for 2305? #4
orlo said:
Hi:
He could also buy and install his own lites.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
3in Poly Pipe (A49461)
