ROPS for B7200
   / ROPS for B7200 #1
scram1995
Hi. Can anyone provide me with insight/sources/advice on the best place to obtain/install an ROPS for a 1986 B7200HST?
I'm considering purchasing one, but I'd like to know how much it'll cost to make it safer.
Also, can anyone tell me what the standard tire/rim size on these tractors was (with AG tires)?
thanks!
   / ROPS for B7200 #2
Scram,
Check with your local Kubota dealer. Kubota has a <A target="_blank" HREF=http://www.kubota.com/rops.cfm> ROPS program</A> where they sell them cheap. Look on this site for the discount certificate and print it out and take it to the dealer and have them order it. They'll charge for installation, but $148 for a rops and seatbelt for my L345 was too good to pass up./w3tcompact/icons/smile.gif
   / ROPS for B7200
Thanks for the info. I just went to the site and printed out the form.
I also just called our local dealer to ask how much it would cost to install. They said that the first one they did took 8 hours and cost about $400, but Kubota just came out with a new install kit that is supposed to reduce the time down to about $200.
Any insights on what it *should* cost to install the ROPS kit they provide?
Thanks!
   / ROPS for B7200 #4
Scram,
My rops is backordered, so I don't have it yet, but I was quoted the same estimate - 4 hours @ $50/hr.
I think it's a great price, considering the big $$ I've seen for other brands and what the price used to be for Kubota rops. If you want a rops (and I do), it's a no-brainer.
   / ROPS for B7200
thanks.
what kind of tractor do you have? I'm considering this 86 B7200 with Kubota loader. Its four wheel drive, but it's got a ton of hours on it. The meter reads 487, but its gotta be at least 1487 and probably 2487 based on the condition of the tires, paint, etc. It runs like a top, starts right up. no smoke. everything seems to function perfectly. I'm figuring I'll need to spend $350 or so on tires right away and then $400 for the ROPS. The owner is asking $5200 for it. Think that's a good price or should it be lower based on the hours and condition?
thanks again for your help!
   / ROPS for B7200 #6
Scram,
You also might check <A target="_blank" HREF=http://www.tractortips.com>TractorTips</A> for original specs on this model. It's kinda tedious, since they have a very slow server, so be patient.
   / ROPS for B7200 #7
Scram,
I have an early 80's L345. Bought it with a lot of hours on it, but it's in pretty good shape.
I don't have any idea of the pricing on a B7200, but look in the Reviews section for a similar model. Also, search the User List for B7200 in the tractor field. Search the forums for B7200 posts. This site is overflowing with good information - just look for it.
I'm sure other B7200 owners will soon respond with their opinions, but if not, try posting your request in the Kubota Buying/Pricing forum.
   / ROPS for B7200 #8
I have a '97 B7300 which is probably pretty close to what you have. I paid about $12K, which included the tractor, FEL, and a brush hog. I can also tell you that at the time I was looking the best used tractors I could find were in the $6K range - and that was usually for a much older Ford 8N or maybe 9N (not 4WD).
From everything I've heard, the hours on your tractor aren't as important as how well it was maintained. Sure, use is use, but if it was serviced regularly and properly it should go for quite a while longer.
...Chris
   / ROPS for B7200 #9
I have a '78 B6100. When I got it, I bought the ROP from the Kubota dealer ($148) and installed it myself in about an hour and a half. It came with good instructions, including pictures. Most difficult part was rigging up a way to suspend it from the garage ceiling beams to position it right so I could insert the bolts. Had to take one rear wheel off so the lower 3ph shaft could be pulled out. It attaches around the case below the 3ph top link bracket area.
The drawback I found of this particular ROP/Tractor is that the ROP bars are barely wider than the top link bracket. I found when I rented a Woods post hole digger that the tube for the PHD would not fit between the ROPS bars and attach to the top link bracket. A Danhuser post hold digger will attach because the tube "necks down" for about 6". But even the Danhuser binds between the ROPS bars before it gets to full up on the 3ph.
I'm going to have to do some careful measuring when I buy my PHD.
Just be aware of this if you already have attachments and are planning to add a ROP.
   / ROPS for B7200 #10
Bill,
This is great information. I was hoping to try and install mine myself and wondered what was involved. My tractor is out in the boondocks and it will be much easier /w3tcompact/icons/hmm.gif and cheaper/w3tcompact/icons/grin.gif to install it onsite rather than take it to a dealer.
Another post had suggested that dealer installation was a real plus because it was fairly difficult to install, but Eric's post earlier in this thread indicates that they may have simplified the process now. We'll see - and I may check back with you when I get my rops.
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
