Roots in sewer?
   / Roots in sewer? #1
countrybumpkin
Elite Member
Kioti, kubota
What in the world can a person do to keep tree roots out of the sewer line, going from the house to the septic tank? They seem to be entering the pipe in two places, both are were the pipe was cut a few years back and spliced back with two rubber couplings with clamps.
   / Roots in sewer? #2
I have used copper sulfate crystals in my drains to ****** growth of roots. Works good. I purchased it from local hardware store. Follow directions on can closely. I have not used it in recent years because I removed the offending trees. /forums/images/graemlins/wink.gif
   / Roots in sewer? #3
What kind of tree? Some species, such as willow, will seek out roots from a great distance. The best way I know of in that case is to remove the tree.
   / Roots in sewer? #4
If you know the place and it's not too much trouble. Dig it up and encase the joints with concrete.
   / Roots in sewer?
looks to be some type of maple tree, As for removing it , That would be the last resort. I really sure the two spots are were it was spliced with the rubber couplings.
   / Roots in sewer? #6
Those roots will do amazing things to seek warm nutrient rich water. The roots must have a way in. Whether a crack, loose joint, or break.
Another last resort is to burst in a new pipe. That is, pull a new smooth wall pipe through the old pipe with a winch. Companies do it out here and it is amazingly effective.
   / Roots in sewer? #7
Sounds like a perfect excuse to buy a backhoe /forums/images/graemlins/laugh.gif
The rubber couplings should be rootproof. Other than digging it up, if you have a 4" pipe cleaned with 4" blades, not 3's or jetter, then it should last 3-5 years or more. The copper sulfate will slow them down or better is the foaming type stuff.
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2009 Pierce 105ft. Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
