RootRipperZilla
   / RootRipperZilla #2
Unless you're getting paid by the machine hour, it makes a lot more sense to simply use bucket to cut a few main roots, push the whole tree over, cut the log(s) off, and with a thumb pile up the rest for burning.
   / RootRipperZilla #3
1) you have much more leverage with the tree still attached to the stump
2) you have a root ball that it totally eliminated, with no stump regrowth to deal with
3) you wouldn't waste much more time on a hardwood stump, not sure it would work on an oak/locust/hackberry stump they are much tougher!!!
4) agree with andy, you would spend far less time cutting roots around the stump then pushing it over while still attached to the tree
not to mention you need a larger machine to use that unit than digging around the stump and pushing over with the tree still in tact
   / RootRipperZilla #5
The biggest advantage I see is it leaves the stumps mostly dirt free and easily burnable. Which on small stumps like those doesn’t really matter because they shake pretty clean anyway. You don’t usually dig up lumber trees roots and all because it makes a mess of the tree.
   / RootRipperZilla #6
I'd agree it wouldn't leave much dirt on what's left of the stump.
We do it all the time if the area is to be completely cleared. These for example were done that way.
enhance
   / RootRipperZilla #7
Its a beast,but I rather have bucket w grapple less of mess.
   / RootRipperZilla #8
enhance
How do you go about burning the stumps? My experience is the big ones make a mess of the pile and burning at all is difficult. If you do get it to burn it requires at minimum twice a day babysitting to push up and knock more dirt off. I think this would be a huge assist dealing with big stumps. Under 12” not so much.
   / RootRipperZilla #9
We dig out a big hole, put some "Firestone ignition devices" in the bottom, drop a lot of the brush in on that, and get it going good. Then drop the stumps in on top that and keep adding brush. It's usually a whole day of burning and beer consumption. What part of the stumps that doesn't burn gets back filled in the hole.
I'd agree with you busting the stumps up would make shorter burn time, but you still just about have to attend it a whole day or two anyway.
   / RootRipperZilla #10
Why do you dig a hole? I’ve never tried that on large scale only with a campfire but I found it much harder to burn like that.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2015 FORD F-550 SUPER DUTY XL (A52472)
2015 FORD F-550...
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
