Grapple Root Grapple
   / Root Grapple #1
TheRegMan
Bronze Member
Morehead City, NC
There's a lot of threads here on root grapples but I don't believe I have seen anything on this company,
Skid Steer loader attachments
Was just wondering if anyone had any experience with them and knew anything of their quality. From the web page info, they seem to have quality grapples at reasonable prices.
Thx,
   / Root Grapple #2
Thx,
It's where I got mine and I'm very happy with it. It's heavy and I've abused it but it refuses to break or bend. I use it primarily to grub out brushy stuff (yaupons) by the roots and to carry brush from point A to B.
It has come in handy too for grabbing and lifting things. I used it to move a cattle guard and a 10x10 wood deck with good results.
   / Root Grapple #3
They build a very good product. You need not hesitate to purchase one.
   / Root Grapple
Thanks to the both of you. I was wondering about them because they are about 175 miles away so I could actually go pick it up. I see Markham is also in Denton, NC so I guess it will come down to price. Everyone seems to be happy with Markham also from what I see. I do like that the SkidSteer people powder coat their products though.
Thanks again!
   / Root Grapple #5
What size tractor are you going to use with the grapple? Seems like most of the guys here lean towards the 48-60" grapples. Mine is 81" heavy duty with the 2 grapples. I am happy with it, but I use mine differently than most here.
   / Root Grapple #6
Those look very good, but look like Markham clones. I would advise a narrower grapple with only one upper claw. and I did not see that in their listing. Their prices seem a little higher than Markham. I feel a 48" is ideal for most applications, especially if you want to uproot and dig up trees, which is what I use mine for mostly. The narrower width (48") allows more focus of digging pressure, say when attacking a root ball. You can really concentrate the digging pressure rather than distributing it over a too wide area. And the narrow one is cheaper, lighter, and one upper claw holds debris in just fine. Once you clamp something with the upper claw, it's not going anywhere. As far as paint, the Markham is just spray painted, but who cares? Just like a bucket, there is not going to be any paint on the ""business end" anyway. Mine is a year old and has been used and abused and still looks fine.
My advice (if your tractor is a 45 horse or better) is to get quotes from both on a 48" with one claw, made from 1/2" steel with extra spacers in between the main teeth resulting in a 4.5" spacing. For a smaller tractor, go with the standard 3/8" steel. Markham made one like this for me and it has been awesome. Seems like it costs around $1400 last year if I remember correctly. This thing will really clear some land. I regularly push down 6" trees and dig up the roots. Hit them high to push them over and then push the teeth under the roots by driving forward and curl. Most will pop out. A wider grapple would not engage the root ball as well, as most root systems are only several feet wide. Sometimes for really stubborn roots, I use the corner of the grapple and only two or three teeth to concentrate the pressure. Thats my opinion after having used one extensively for a year.
   / Root Grapple #7
Thx,
I bought my rock bucket from them and have been very impressed. The design of the one I actually got was superior to the one in the picture. It is more like a very beefy root grapple with bolt on side plates.
It turns out that the reasons I wanted a rock bucket evaporated with a little experience, but by removing the side plates I turned it into a grapple and it is great.
I have enough FEL capacity that a little extra weight in the grapple isn't a big negative, and I have had a lot of uses for it.
I would buy from them again with no hesitation.
   / Root Grapple #8
Thanks for that link! Their pallet forks are very well priced too.
   / Root Grapple
Thanks for all the replies. I am still tractorless at the moment but planning to get the Kioti DK40SE. It has a strong front loader and should work very well with the grapple.
HCJ, I like your comments on the 4' grapple and explanation on why it is better than the wider ones. Makes very good sense. I was kind of leaning towards the 5'-6' for debris removal but I suspect the 4' would do just as well with the added benefit of being better for getting under the roots as you explained. Not to mention saving some bucks. :D
   / Root Grapple #10
There are a couple big fans of the narrow grapples in here. Mine is not a lot wider at 56" but it does have two arms which I think are better at many things. To be fair I have never used a grapple with one but I don't think they would be as good holding a unblanced load of tree limbs or picking up and stacking 800 lb bales of hay. To each their own.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
