Root Grapple Connectors
   / Root Grapple Connectors #1
jake98
Veteran Member
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Hello to the group,
I'm installing a root grapple to the front of a compact tractor loader, and I'm being told that the hyd. connections go on the back, and it seems stupid to me. I don't have intentions of adding a back-hoe or any other hyd. tool to the back so why put the connects back there?
Thanks, Jake
   / Root Grapple Connectors #2
First, Welcome to TBN:D
Second, What tractor are we talking about here?
The auxiliary "remotes" offered by most manufactures are ported to the rear for use in blades and other rear mounted implements. There are a lot of people who just use long hoses extended from the rear to the FEL to operate grapples, and some install "electric diverters" that "diverts" fluid from the dump/curl circuit to the grapple when a button is press on the joystick handle. These diverters will cost about $500-$600 depending on the application.
If you do a search here for these terms you will learn a lot about these setups, it's one of the most talked about items here.
diverter
grapple
joystick
fasse
wr long
millonzi
Please feel free to ask more questions;)
Thanks Kenny, I'll search those topics. I have a Kioti CK25HST, a '53 Farmall Cub, and a JD 410. The grapple is going on the new Kioti.
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
