Roosa Master DM governor issue - John Deere 6404 engine (used in JD4020, etc.)
   / Roosa Master DM governor issue - John Deere 6404 engine (used in JD4020, etc.) #1
petes
Bellingham, Washington
Kubota B8200 (21hp) , IH B275 (28hp), JD 1830 (68hp)
OK, so the engine(s) aren't in one of my tractors, but in my trawler - Grand Banks / American Marine marinized Deere 6404 tractor engines with Roosa Master DM injection pumps.
One engine, particularly when warm, occasionally stalls following shifting into gear from neutral (i.e. applying a load, but still at idle). Neutral idle is about 800 RPM. When load is applied the revs on that engine will dip to about 500 rpm. Sometimes RPMs continue to drop and it dies, sometimes it recovers after 2-3 seconds to a steady governed 800 rpm. I recall it dying a time or two when quickly throttling back to idle from cruise (1250-1400rpm) while still in gear. The other engine handles the step load just fine without faltering. If I throttle up to around 900 rpm in neutral I can shift without stall, but that's rather aggressive for docking maneuvers (7.5-8kn at 1250rpm, about 4.5-5kn at 800 rpm), albeit better than stalling - I have to run down and around the boat to the main helm inside to restart.
I'm looking for suggestions/advise as to what might be wrong, and whether it something I can fix or if it has to be taken in to a shop. I've taken apart and repaired/adjusted a couple inline and rotary pumps successfully, but they were all "more broken" than this one so the risks were worth it...
   / Roosa Master DM governor issue - John Deere 6404 engine (used in JD4020, etc.) #2
No problem Capn'.. I can walk ya thru it.. I HAVE TO HAVE the Dm #'s off the pump first.. so we can get the correct idle spring..
Once we get in there, the problem will/should be obvious but we'll change the idle spring to be certain we fix the problem.
Just send me an email & we'll continue.. Click on my name to the left.
Just checking to see if you got my email...
   / Roosa Master DM governor issue - John Deere 6404 engine (used in JD4020, etc.) #4
I did but there was a problem w/ my response..
If I try to answer using this forum's email, you have it turned off.. "The recipient has requested no emails".. so I couldn't respond using this forum.
& u provided 2 additional email address in your email.. "Pete" & "Ford".. I sent an email to "Pete" & got no response..
The file I want to send u is "sensitive" & wanted to make sure I had the correct address before I sent it..
And naturally I forgot the subject of this thread, so I couldn't come back & respond that way..
Send me another email or private msg. w/ ONE email address you would like me to respond to.. Thanks, TPG
New message sent...
Pete
   / Roosa Master DM governor issue - John Deere 6404 engine (used in JD4020, etc.) #6
I sent the file.. let me know if you get it. TPG
2017 Ford F-550 Valve Maintenance Truck (A50323)
2017 Ford F-550...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
3014 (A50657)
3014 (A50657)
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
Ford Super Duty 4x4 Pickup Truck Bed (A49461)
Ford Super Duty...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
