Roofing discussion!!!
   / Roofing discussion!!! #1
nwut05
SW VA. BRISTOL
New Holland T-1510, T 4.75
Hello all, I just wanted to get some other opinions and objective discussion about a situation i came across this weekend. I observed a roofing contractor who installs a lot of tin roofs. He was doing something i thought was maybe worth discussing. I observed him working on an existing roof that was shingled and he was putting new tin over it. Now here is the questionable part. Instead of rolling the tar paper/felt the length of the house, starting at the bottom, and overlapping to the eve. He was starting at the end of the house and rolling from one side to the other overhang to overhang, or gutter to gutter per say, overlapping as he went about 8 inches. Now i do know this contractor somewhat, and confused about his new tar paper technique, i approached him. I had to ask him why he was doing that? and his response was it did not matter which way he ran the tar paper over existing shingles???? and after some friendly discussion i decided the best thing i could do was move on and not try to change his mind anymore! So what do you guys think will his way work. i personally think it would open up more opportunity for leaks????
   / Roofing discussion!!! #3
It certainly wouldn't be easier to run it that way. Well, to me, it wouldn't be easier.
So this completed roof has a layer of tar paper, a layer of shingles, a layer of tar paper and tin sheeting.
I can't see that the newly added layer of tar paper is doing much anyway?
And if the roof develops a leak it probably won't breach the vertically ran, 8" overlap anyway.....
I'll yield to the expert and say it doesn't matter.
   / Roofing discussion!!! #4
The paper isn't for waterproofing, it's simply to keep condensation from dripping inside. If it already has a shingled roof ( I wouldn't put tin over a shingled roof) I see no need to install tar paper. If the roof shingles are bad enough to need tin, they should be torn off and thrown away.
Any of you seen paper on a pole barn? If so, how was it put on? It would be difficult at best to run it laterally.
   / Roofing discussion!!! #5
The tar paper is actually a slip sheet at that point.
It is a barrier between the granular surface of the shingles and the underside of the metal roof.
   / Roofing discussion!!! #7
   / Roofing discussion!!! #8
Don't think I want to use that roofer. Don't like the idea of putting tin over shingles. Not the most even base. Certainly would have want him to be rolling the tar paper vertically.
Ralph
   / Roofing discussion!!! #9
That is the reason I'd use tarpaper over shingles IF I was going to install metal over shingles....which I wouldn't personally.
   / Roofing discussion!!! #10
'A few bucks' could double or triple a job cost. I've got over $7,500 in my metal roof and that's over existing shingles. No way I could have afforded a full tear off. I don't know how long it will last before problems develop, but I hope I'm long gone before then.
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
