roof shingle question
   / roof shingle question #1
bellweather
Platinum Member
Western MA
Kubota BX22
The bozos who installed my roof left way too much shingle hanging over the eve, making it very difficult to clean gutters. I want to trim back the shingles a bit but am unsure of the best approach. I am considering using my Skill saw with an abrasive blade. I assume cutting by hand with some kind of a knife will be way too laborious. Any thoughts? Thanks
   / roof shingle question #2
Why not add to the fascia board. I have this problem where the roofers expected the gutter guys to put in a 2x4" fascia board. The gutter guys mounted the gutters directly to the ends of the trusses, nice eh? I can't get my big paws in there to clean it so I go the easy route. Pop off the downspout and wash everything down the gutter to the opening.
Your shingle ends will look bad if you cut them, and that last row will be short. This is a very visible part of your house and I wouldn't risk a hack job.
The worst part about roofing is cutting the shingles. I cut them most of the way through with a box knife and then bend them until they snap. This is very difficult to do after installation.
   / roof shingle question #3
I have the same problem on my barn roof, only I'm the bozo in this case...I read that you can trim them with a circular saw with the blade in backwards...I'm guessing an abrasive blade or a fine tooth plywood blade would have the same effect. The trick is to cut them without snagging and ripping.
   / roof shingle question #4
They really aren't all that hard to trim with a hook blade in your utility knife. Just strike a line and have at it. I've trimmed hundreds of feet that way when I used to do architectural sheet metal for a roofing co.
I would be afraid the base of a circ saw would be hard to guide over the layers of shingles, knock some of the grit off and be more trouble than it's worth, not to mention gunking up the blade with tar. Of course, on the positive side it IS a power tool. /forums/images/graemlins/grin.gif
snapping a line and using a hook blade sounds promising, or perhaps scoring and snapping. I wasn't too keen on using the circ saw for the reasons mentioned elsewhere. I can't thicker the facia board...I mean I can, but that would be way too much work for this buckaroo, though it sounds like it would work. thanks for the advice guys
   / roof shingle question #6
I actually used tin snips on the shingles that were on my roof that had been installed to far out. They seemed to work fine.
   / roof shingle question #7
What do you consider way too much?
I would think you might want/need, maybe 3/4" to keep water from getting behind the gutter, if it is like some.
   / roof shingle question #8
I clean my gutters with my leaf blower so no need to get the hands in ever. Of course I do have a ranch with a 4/12 pitch so walking along is easy. It would probably be much more difficult on a ladder and more of a mess but still could be done with proper eye protection and suit up.
It's the slickest easiest way to get it done and it only takes few minutes when walking on the roof /forums/images/graemlins/grin.gif
Might eliminate the need to cut the shingles at all /forums/images/graemlins/laugh.gif
   / roof shingle question #9
Is it possible to post a picture of what you are describing as this may help with an answer to your question? Like some have mentioned that they left them that way for a reason.
Steve
I'll snap a picture. I am aware of the need for some overhang so as to keep water from getting under the shingles and behind the facia, however the new roof overhangs a good 2" beyond the previous roof. Even if I can trim off 1", it will facilitate cleaning the gutters. Using a leaf blower might work in the fall, but in the spring we get so much sludge from the trees and it stays wet. I actually scoop out buckets of the junk. When I'm done, I hose it all clean. It's a twice a year ritual.
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
Miscellaneous Pallet of Road Safety Signage (A52384)
Miscellaneous...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
