Rollover vs. box blades??
   / Rollover vs. box blades?? #1
Anonymous Poster
Epic Contributor
Has anyone had any experience using both rollover blades and standard box blades. The rollover looks much more efficient since you can set it 3 ways, to wit: drag/pull with side panels, backfill/push with side panels and scarf/rip only. I've seen one at a local cemetery and they are easy enough to switch positions from the seat. And, they look like they would do a better job and be easier to use teeth only, etc. But . . . since I havn't actually used them I don't really know whether they would be that much more efficient - especially since they seem to cost 2 1/2 to 3 1/2 more money. So, any advice as to whether they are actually that much more efficient at moving/leveling/backfilling soil???? Thanks. JEH
Thought I would answer my own post. Below is review of a rollover blade. Cost: $1125. Model: LPRO2572. Bot new May 2003.
Was getting ready to purchase a straight box blade but saw the rollover type in some literature. Rented a Woods rollover to test and found it much superior to a straight box blade.
The Woods had a metal brace/support running from the middle (up/down) of the moldboard to the middle of the side plate which tended to clog easily (moist soil sticking between the brace and the moldboard/side plates. The Landpride model did not have that yet seemed just as sturdy.
The rollover allows forward scraping without rippers interfering, backfilling with side plates to keep dirt in, or, just ripping alone. It takes only seconds to switch, thus you can rip, flip the blade, then scrape. If soil is loose enough, and you don't need the rippers you can just blade. Switching (raising/lowering/removing) the rippers on a standard fixed box blade is a pain.
The RO2572 seems very sturdily built and looks like it will last indefinately. The upper/lower edges of the moldboard can be reversed or replaced. In addition, the teeth on the end of the rippers are replaceable. So, all wearing edges can be kept new.
The only weakness is that there are no grease nipples at the bearing points, however, the fit is loose and you can easily spray litium grease into all pivot areas.
Although the price was 2 - 2 1/2 times a straight box blade it is well worth the extra money when you calculate how many cubic yards per hour/day you can move with it vs the straight box blade. In addition, you will get some of the additional cost back on resale.
JEH
   / Rollover vs. box blades?? #3
I've never used one, but looked at one at the dealer's place and the only reason I didn't buy it was the price. /forums/images/graemlins/grin.gif
Bush Hog 20' Mower (A50123)
Bush Hog 20' Mower...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A53843)
2021 QUALITY...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2025 AGT ATK-B1000 (A50123)
2025 AGT ATK-B1000...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2014 Ford F-550 Altec AT37G 37FT Bucket Truck (A51692)
2014 Ford F-550...
