Rockshaft quit rockin !!!
   / Rockshaft quit rockin !!! #1
pat32rf
Veteran Member
Bancroft, Ontario
JD4300
The other day a couple of younger (40ish)neighbours who owed me a favor came over to cut, split and pile a bunch of firewood for me. I wasn't home at the time and they couldn't get my old woodsplitter hooked into the hydraulics. Been a couple of years since I've used this particular splitter myself, but when I got home at 10am I hooked it up and they spent the day doing about 2 bush cords. I then removed the splitter and stuck my weights and skiding winch on the 3pth.
The next day we were moving a bunch of stuff between our old and new abode with the snow bucket and at one point I dropped the 3pth "anchor". When I went to lift it to move, it wouldn't raise.
I just pulled the pins and left the weights on the ground so we could get stuff moved before it rained.
Today I got out the book and isolated the problem to the valve.
Pulled off the plastic, seat, shift handle (JD 4300HST) etc so I could get at the valve.
When I pulled the valve cover (housing) off, I found a well chewed "O" ring drifting inside.
I then pulled the valve itself off (a Sauer Danfoss unit) and could see a piece of "crud" holding one plunger where it shouldn't be.....The crud turned out to be a piece of sintered brass, which I was lucky enough to get out by partially dismantling the valve itself.
My book gives lotsa detail on the 3 spool FEL valve but nothing on the rockshaft valve so I tried to call Danfoss as I wanted to know if the O ring could be out of it's innards or from something farther upstream. After calling South Carolina and then Illinois I gave up. (I'm in Ontario)
Before I re-assembled everything I checked the inline filter on my "Power Beyond". Sure enough, the bottom of the sintered brass element had a chunk missing, as well as a sealing ring that was only partially there.
Once I got everything back together it all seemed to work. I just hope I got all the brass out of the lines ......
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
