Rockshaft Pin Removal -- 4410
   / Rockshaft Pin Removal -- 4410 #1
jeffinsgf
Veteran Member
Springfield, MO
JD 4410
I've done some damage to the pins in my rockshaft. I took the nut off the inside, but it doesn't seem to want to budge. It appears to be threaded into the rockshaft, but I couldn't get it to budge, even with a reasonably big cheater bar.
Is it threaded into the rockshaft or is it a press fit?
Any help on getting them out?
Well, here I am answering my own thread...
The pins are tapered. Theoretically a couple good smacks with a hammer should pop it out. Have the replacement pin in hand now, I'll let ya'll know how it goes tomorrow.
   / Rockshaft Pin Removal -- 4410 #3
Not really sure what part you are talking about.
   / Rockshaft Pin Removal -- 4410 #4
I believe he is referring to pin #20. They are tapered and once the nuts are removed, a good whack with a 3 lb hammer should pop them out.
That it did. Easy peasy.
   / Rockshaft Pin Removal -- 4410 #6
I was thinking off of shaft 14. Picture is worth 1000 words. Glad you got it fixed!!
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
FREIGHTLINER BUCKET TRUCK (A51406)
FREIGHTLINER...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
