Rockshaft Controls - 3010
   / Rockshaft Controls - 3010 #1
Luray Farmer
I am still getting to know my JD 3010. The rockshaft control on this tractor has three settings: Load, Depth, and Load/Depth. The operating manual explains how these work. The problem? I get rockshaft movement (up/down) only in the "Depth" position which is the lowest position of the shifter knob. If I set the control in "L" or "LD," moving the control level on the dash has no effect. If I have a load suspended using "D" and move the selector to another position, the load drops.
What might be the issue? I can use the hitch on "D" for some things but it worries me the other two settings seem inoperative.
Bill Shields
Luray, VA
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
1267 (A50490)
1267 (A50490)
(4) Magnatex Pumps (A50121)
(4) Magnatex Pumps...
Tires (A50121)
Tires (A50121)
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
P.T 10' Mower (A50121)
