3-Point Hitch Rockshaft control lever sensitivity problem
   / Rockshaft control lever sensitivity problem #1
NWSeadog
Western Washington
John Deere 770
This is probably a noob question. I just acquired an older JD 770. The rockshaft control lever only seems to do anything (raise/lower the 3PH) in the 6 to 8 range. Is there an adjustment for this or is it a repair issue?
Also the adjustable depth stop appears frozen. It is all the way down at 1 and I'm unable to get it to move. I'm assuming you rotate it to loosen it, slide it to the position you want then tighten it back down. Any ideas there?
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
New Holland 273 Hayliner Square Baler (A50515)
New Holland 273...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
T3 Motion Patroller Segway (A51694)
T3 Motion...
Deere 302K (A50120)
Deere 302K (A50120)
